It is currently Sat Sep 22, 2018 7:30 pm
PostPosted: Wed May 15, 2002 1:05 am
Overclocking the easy way?
Download the software by using Yahoo search engine? Especially CPUfsb and softfsb.
CPUfsb uses motherboard, PLL to do FSB frequency changes.
Softfsb uses chipset name(or similar chipsets) to get PLL changes.
They both let you reach the impossible, which is lockup. Reboot with standard setting and re-overclock until everything works. But both has to be re-overclocked each time you boot.
Have fun?
 Post subject: Query
PostPosted: Thu May 16, 2002 6:09 am
Your saying this will discover the frying point of cpu without frying the cpu? This is the safest way to overclock?
PostPosted: Thu May 16, 2002 2:38 pm
You do have to shut down as quickly as possible, once the cpu locked up.
If you have WinMe you have scandisk repeated over and ever again, each time you boot again after illegal shut down?
PostPosted: Thu May 16, 2002 7:21 pm
Lord Of The Realm
I do not call that the easy way I call that the sloppy method as it does not work well at all.
True overclocking comes from altering the boards natural on-board setting not some sloppy software job......
Software is not really a viable solution and works different from board to board.....
PostPosted: Thu May 16, 2002 7:31 pm
I agree. easier to go through the BIOS.
________
TCstangs
PostPosted: Thu May 16, 2002 7:39 pm
Lord Of The Realm
Exactly...................................... 8O 8O 8O
PostPosted: Thu May 16, 2002 7:56 pm
plus if you get the wrong PLL theoretically you could screw it up.
________
buy extreme q vaporizer
PostPosted: Fri May 17, 2002 10:59 am
Then why the hell did atang1 use his time posting such rubbish and poppy cock?
PostPosted: Fri May 17, 2002 11:05 am
Lord Of The Realm
I thinke he means well and after all it is only an opinion. 8O
I do not agree and it seems neither do the rest of you. :(
I will continue the classic BIOS method.... :D
Take care all
PostPosted: Fri May 17, 2002 7:37 pm
I think the fact of the matter is windows program is much easier to control the PLL circuits than a non-UPDATable PNP BIOS. Bios generally stops you from controlling the PLL.
When you use the wrong PLL signal, nothing happens. Hardware PLL can not be damaged by a software signal. Disclaimers on the CPUfsb is just to protect the progrmmer himself legally, so he can have a clear conscience. And you will not overclock to damage your cpu or other parts such as chipsets by overheating.
Sometimes, some of us did not understand windows program can override the limitations in the bios.
Admit you are wrong? Maybe a little bit wrong? Maybe ieeny weeny weeny bit?
