Newbie FSB Question
Newbie FSB Question
Postby dharbert » Tue Jul 02, 2002 6:18 pm
My BIOS won't let me adjust the FSB or the voltage. Is there any way I can adjust the FSB and voltage through a software app, and if so, what is the best one to get?
Any help would be greatly appreciated :)
dharbert
Postby Toby B. » Tue Jul 02, 2002 11:00 pm
provide a little bit more info on configuration and we may be able to help
Motherboard:
CPU:
RAM:
Toby
Toby B.
Postby dharbert » Wed Jul 03, 2002 1:34 pm
I have a "Bryant" Gateway OEM motherboard with an Intel 810E chipset. I am currently using an Intel Celeron 500Mhz PPGA (Mendocino) processor and 256MB PC133 CL3 SDRAM. The BIOS is an Intel AMI and my current BIOS version is WL81020A.15A.0007.P06
The FSB is set to 66Mhz (limitation of the Celeron chip), but will go up to 133Mhz. There are no jumpers on the board and there is nowhere in the BIOS to set the voltage or the FSB.
dharbert
Postby Tolemac » Fri Jul 05, 2002 12:02 pm
Unfortunately, you are stuck. Unless you get a different mobo, if you can find one that would fit the Gateway case that is, you will not be able to overclock that unit.
Tolemac
Postby dharbert » Fri Jul 05, 2002 3:26 pm
Thanks Mr. Fu! :D
dharbert
Users browsing this forum: YandexBot [Bot] and 4 guests
