Cyrix OC
Cyrix OC
Postby MilkMan41 » Tue Jul 02, 2002 5:51 pm
Hey, I wanted to know if i could get some help OCing my Cyrix 8x86MX.
Iv never over clocked and will need some detailed help, if anyone is up to it. Its at 333 now and needs a lil boost. heh. thx
MilkMan41
Postby Tolemac » Tue Jul 02, 2002 6:11 pm
Never heard of anyone OC'ing a Cryix, but I guess it's possible. Depending on your mobo, you will have to up the Front Side Bus (FSB) to get more out of it. Check your manual to see if you can adjust the FSB by way of jumper on the mobo itself or if you need to go into the BIOS to do it. Find that out and post it back here.
Tolemac
Postby MilkMan41 » Tue Jul 02, 2002 6:59 pm
Ok. i found my jumper settings, and is CPU core voltage the same as FBS??? My physical manual i was never given when i purchased it new 4 years ago, so im counting on one givin to me in the Mobo id. forum.
MilkMan41
Postby Tolemac » Wed Jul 03, 2002 9:17 am
No. CPU core voltage and Front Side Bus are two different things. Only adjust the FSB for now.
Tolemac
Postby MilkMan41 » Wed Jul 03, 2002 7:50 pm
Where are common places to change FBS? i dont have it in my BIOS, and not on jumpers.. anywhere else?
MilkMan41
Postby Tolemac » Fri Jul 05, 2002 12:14 pm
If you have thoroughly searched all of the BIOS and there is no adjustment for it and there are no jumper setting to change it, then you cannot. You will need a new mobo to do any overclocking.
Tolemac
