overclocking advice please
Postby gogadgetman » Mon Jul 01, 2002 4:43 am
i am a bit of a novice at this but here goes the questions.
motherboard Soyo SY-K7V Dragon Plus
cpu anthlon 1.4 FSB 133 unlocked with pencil trick
ram 256mb ddr2100
temp in bios 59 degrees centigrade
os windows XP
can not get cpu to overclock above 1.533. will not post above this. any advice would be much appreciated
gogadgetman
Postby The Disturbance » Mon Jul 01, 2002 4:56 am
Your temps are way too high :!: Your should get some Arctic Silver 3 and a Thermaltake Volcano 7 hs/f! What are you using now?
The Disturbance
Postby gogadgetman » Mon Jul 01, 2002 5:06 am
i am using artic silver 3 and a heatsink and fan rated for a XP2100+ cpu plus one extra case fan
gogadgetman
Postby The Disturbance » Mon Jul 01, 2002 6:16 am
1) Are using only a paper-thin layer of AS3?
2) What hs/f are u using...brand/model
3) You should have a case fan in the front for intake and ony on the back for blowing out...
4) get the Volcano 7+ cheap from www.novapcs.com ...its only $25.00
The Disturbance
Postby gogadgetman » Mon Jul 01, 2002 6:38 am
probably used to much as3. i think hs/fan is a Coolermaster but cant remember which model. just checked temp in Bios 49C @ 1.4mhz not overclocked.when computer on for say 8 hours temp reads 54C at idle not overclocked
gogadgetman
Postby The Disturbance » Mon Jul 01, 2002 7:36 am
Your temps. are OK when it isn't oc'ed...as for o/c'ed I would say to try out the V7 from www.novapcs.com and maybe add another case fan...
The Disturbance
Postby gogadgetman » Mon Jul 01, 2002 10:35 am
does anyone no if this heatsink and fan will fit on my motherboard without snagging anything else on the motherboard for example the capacitors? how noisy is it?
gogadgetman
Postby The Disturbance » Mon Jul 01, 2002 11:16 am
The V7+ is pretty noisey from what I have heard...
I looked at your board and it looks like the V7+ should fit.
The Disturbance
