It is currently Mon Sep 24, 2018 9:33 am
PostPosted: Tue Jun 25, 2002 1:22 am
Dear readers,
I read with interest about the pencil trick for AMD processors, and with much enthusiasm decided to give it a try. I have an Asus A7M266 board and an AMD 1.4 (266fsb) CPU.
In my bios settings the multipliers are of course greyed out, BUT when I looked at the L1 bridges on the CPU, they have NOT been cut, I mean they are intact as supplied..... I don't understand what's going on!!!
I also noticed that one or two of the others such as L2, L3 L4 have been cut, and some left alone.
Any explanations gratefully received.
PostPosted: Tue Jun 25, 2002 8:43 pm
The cut is not very noticable, but it is there. Trust The Doc, it works. I have done it. BTW, the CPU multiplier settings are probably set to auto. Change that and do the pencil trick and you are on your way.
PostPosted: Wed Jun 26, 2002 12:38 am
No seriously, the cuts are NOT there! I have even inspected it with a very high magnification lens.... Also, bios is set to manual and is jumperless.
N
PostPosted: Wed Jun 26, 2002 6:33 pm
:arrow: :!: :idea: try and raise the multiplier in bios!
