It is currently Tue Jan 21, 2020 4:18 pm
Post new topic Reply to topic  [ 225 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 23  Next
PostPosted: Wed Nov 05, 2003 10:54 pm
that's it, she won't do no more.
1.925v 200x12.5=2500mhz (amd tbred B 1700+ jiuhb)
heat goes to about 49c at max load (3d gaming) 42c@idle
still using volcano 7+ base but now modded with 80mm tornado.
my comp is now referred to by my friends simply as "ghetto beast".
it has no case, i have it mounted on an old "atari" cartridge case; some of the old timers might remember the one that the cartridges fit in bottom and console ontop.
maybe someday soon i will test your gag reflexes and post pick.
anyway, loud but stable.
cheers.
PostPosted: Wed Nov 05, 2003 11:10 pm
wow. That's a nice overclock for a 1700+. The voltage is high though.
PostPosted: Wed Nov 12, 2003 11:54 pm
470Mhz increase on an AMD XP 2000, from 1.67 to 2.14 with PC2100 DDR!!!!!
Fsb @ 171
Multi @ 12.5
Vcore @ 1.625
Idle temp @ 30-32*c
not tested full load temps yet.
see sig for more :)
PostPosted: Wed Nov 12, 2003 11:55 pm
Crazy Man. Betcha cant do 11.5x200.
PostPosted: Wed Nov 12, 2003 11:58 pm
i might give it a go tomorrow after a few drinks to give me the courage :wink:
PostPosted: Wed Nov 12, 2003 11:59 pm
Remember man HIGH fan speed, voltage. If it gives you the siren, or it starts smoking, it's not Tulatin's fault.
PostPosted: Thu Nov 13, 2003 12:02 am
LOL.
If worst comes to worst what is likely to blow? just the cpu? if so u can pick xp2000's up for virtually nothing so its not too bad.
PostPosted: Thu Nov 13, 2003 12:04 am
at worst, it'll take the board with it. But, most likely the cpu will just go.
PostPosted: Thu Nov 13, 2003 12:06 am
eek, the board is only 3 days old....i think ill pass on your offer :roll:
or i could take it back as "faulty" :twisted:
PostPosted: Thu Nov 13, 2003 12:07 am
it shouldn't blow though - it's got protection for that.
