It is currently Mon Jan 20, 2020 6:18 pm
Post new topic Reply to topic  [ 225 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 23  Next
PostPosted: Fri Sep 05, 2003 6:14 pm
While that may be true, think of the performance caused by the fsb...
PostPosted: Thu Sep 11, 2003 9:35 pm
well right now im at 608fsb from 2.53 to 2.88ghz @ 1.575V stable benchmarked with sisoft sandra and pc mark 2002, running a soyo p4x400 dragon ultra platinum and corsair memory 8)
Luck always follow the prepared mind...
Straight from my beautiful island Puerto Rico
PostPosted: Sat Sep 13, 2003 6:36 pm
Big ups to overclocking!
FSB:200mhz
Multiplier:10.5x
Speed:2.1ghz
CPU voltage: 1.675v
Cooling: stock hsf with ghetto ducting technology.
Temp under load: 43.5 degrees C.
this is my first time overclocking, I think I'll buy a real hsf next week :)
ABS El Diablo Full Tower
Gigabyte GA-MA790FXT-UD5P
Phenom II X3 720 Black Edition (OCd to 3.2GHz)
OCZ Reaper 2x2gb DDR3 1333
Sapphire ATI HD 4830 512mb
Corsair 750W PSU
3x750GB WD HDD RAID5 Storage
1x750GB WD HDD Win 7 Pro-64/XP Pro-32
F@H Team Rank: 17
PostPosted: Wed Sep 24, 2003 1:06 am
try #1..
MSI 6390
XP2000 Palomino (AX2000DMT3C, AGOIA)
would only run stable w/ FSB @ 139, tried upping vcore, dint help..
stock mult...... 139 * 12.5 = ~1738mhz, only 71mhz over
stupid 6390...
try #2
MSI KT6 Delta (Via KT600)
same ole XP2000 (b4 i got my barton)
had it running stable @ fsb 143, had the vcore upped from 1.75 to 1.825
stable,, running 53c idle, 60-65c full load (prime95)
prime95 returned no errors (amazingly)..
so.. 143 * 12.5 = ~1786 a grand total of 121.5mhz OC
im gonna do the l3 unlocking soon.. i swear.. i wanna get at least 1.9-2 ghz outta this sucker.,. i know xp2k's suck.. but i dont care if its puffing black smoke, and smellin like a dumpster w/all 12v running through it :twisted: ,, as long as it boots into xp.. then it can @#$! up all it wants
dIppEr
Athlon X2 4600+
MSI K9N-SLI Platinum
4x1gb OCZ Gold DDR2-800
EVGA Geforce 8800GTS
WD 200g, 250g IDE
WD 320g, 500g SATA
LG H62L, Pioneer DVR212D
Tt XaserIII V2000A
PostPosted: Mon Sep 29, 2003 9:45 am
My first time overclocking:
Base: 2.4GHz @ 34C
With ASUS AI 30% overclock: 3.1GHz @ 40C
I didn't think the Crucial RAM was going to take the inflated bus speed, but it's holding strong. With manual overclocking, I should be able to take it higher, though I may need something other than the stock hsf.
Antec PLUSVIEW 1000AMG Case
Antec 400W PSU
ASUS P4P800 Deluxe
P4 2.4CGhz 800MHz FSB
512MB Crucial PC3200 DDR
80GB Maxtor HDD 8MB cache
ATI RADEON 9800 Pro
Creative Labs SB Audigy 2
Logitech Z640 5.1 Speakers
Lite-On 52x CD-ROM
 Post subject: i can get more outa it
PostPosted: Wed Oct 01, 2003 8:38 am
i can get more outa this guy
but this is were it is at the moment
PostPosted: Tue Oct 07, 2003 5:53 pm
2500+ @ 2.5MHZ. With slk-900 and tornado at full blast was idling at like 55°C. Now that is hot... If I get some extreme cooling, that speed might just stick around. That was 218x11.5 on an Abit NF7, would have gone for a higher FSB but it doesn't let me do anything higher than 218. :( Well, I'd say that my cpu Overclocks quite well :)
I have a belly button
PostPosted: Fri Oct 24, 2003 2:04 am
XP 2000+
FSB @146 mHz
Multilplier at 15
OC to 2.05 GHz with stock cooling.
Idel Temps 31 to 35C
Temp under load 49 to51C
I have another fan to replace the stock cooling fan but it is LOUD :D
Once I build a fanbus for it, will play come more.
Come fold with me....
 Post subject: oO
PostPosted: Fri Oct 24, 2003 9:31 am
2.5@1838...
oc@ 2330...
stable...
PostPosted: Mon Nov 03, 2003 10:40 pm
xp2000+ palomino (i know, pallies aint good for o/c, but it worx)
managed to get 151 fsb running outta it, anyhigher would cause reboots, dropped outta prime95, 150 stable (had to up vcore to 1.8v)
when done was running:
XP Pally 2k+ (AGOIA) 150 fsb, 12.5(stock) mult.
MSI K7N2-DeltaILSR
256 Samsung PC2700 (had another 128 stick of micron2100 in it, but bit the dust)
its not the greatest oc, but for a 2k pally? 150*12.5=1875mhz, so about 210mhz o/c...
dipper
Athlon X2 4600+
WD 200g, 250g IDE
WD 320g, 500g SATA
Tt XaserIII V2000A
