It is currently Mon Aug 10, 2020 11:16 pm
Post new topic Reply to topic  [ 225 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 23  Next
PostPosted: Fri Aug 22, 2003 1:20 am
here ya go:
what chip are u running and would u know what the Sspec on ur chip?
P4 1.8Ghz/ OC'ed 3.07 w/1.65v
Watercooled by: Maze3, Maxijet1200 & F150 Heatercore Temp: Load: 37c Idle:32c
Albatron PX845PEV Pro
Crucial 256mb PC2700
SoundBlaster X-Gamer
PostPosted: Sat Aug 23, 2003 5:18 pm
Is your chip unlocked? Becuase a multiplier of 18 on a C grade chip would be a 2.6C not a 2.4C. I've got a northwood 2A./
PostPosted: Sun Aug 24, 2003 10:39 pm
na mine isnt locked.... here is the sspec code SL6D7
http://processorfinder.intel.com/script ... Spec=sl6d7
PostPosted: Mon Aug 25, 2003 12:50 pm
No wonder - it's a B chip = a 533 one - i thought it was an 800c one! Stupid me.
PostPosted: Mon Aug 25, 2003 3:47 pm
ive read that some ppl w/2.0A were able to go beyond 3ghz but thats with the C1 stepping and different mb. my 1.8A did 3ghz on my BD-7 and Albatron board but would crap out anything higher than 169 fsb. :\ so im pretty sure it reached its limit.
PostPosted: Mon Aug 25, 2003 4:07 pm
Mine topps at 2.95 - with the4 max voltage, it just WONT boot - it starts the beeping wail of death..
PostPosted: Tue Aug 26, 2003 5:27 am
Ok I tinkered with mine some more... both of them! As the siggy says, 2.2GHz and 440MHz FSB. I'll try pushing the FSB up more, but I can't get this CPU beyond 2.2GHz stable. I also got my 2nd comp using an XP2600 to 10.5 x 200 with the Asus board, and it's stable. The Asus is using OCZ's wonderful PC2700 memory overclocked at a 6,3,3,2 timings.
PostPosted: Fri Sep 05, 2003 3:05 pm
Okay, finally got it stable. Here's the rundown:-
MOBO: Gigabyte GA-7VAXP
CPU: Athlon XP2000+ Thoroughbred
Ram: 1GB 266DDR ram (non-specific OEM) (the cheapest I could get)
Cooling: Thermaltake Volcano 7 (max 56degrees under load)
BIOS Settings: 156MHz FSB/11.5x multiplier/CAS 2.5, everything else on normal settings.
This may not be my fastest but this is the most stable o/c I've done to date, and it's my current config. I don't think I've done too bad what with the reputation of this KT400 board.
PostPosted: Fri Sep 05, 2003 3:37 pm
dude - you should just do it 250x9...
PostPosted: Fri Sep 05, 2003 6:12 pm
If my motherboard has it, I'm gonna try 250x8.5.. the CPU doesn't wanna run over 2.2GHz
