It is currently Tue Jul 07, 2020 5:13 pm
Post new topic Reply to topic  [ 225 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 23  Next
PostPosted: Fri Jun 27, 2003 1:10 am
2.75 mhz i could went higher,i dident even need to adjust the vcore.
and that even when i had the 2.5c mem at 2c.
she was rock solid.
i did want to get gready and try 3.0 why mess around.i hate that cpu fan now.
i giong to get a zalman onion,with no fan,and leave only 2 case fans on.
i disconected one.
i always run about 98
2.53Mhz asus p4s8x 533Mhz 512 DDR c2.5 p4dragon4 bios 1004
ati 9700 pro cat3.4
raptor 10k sata si3112
330 entermax quiet
santa cruz turtle beach
sony 52x
tdk 24x10x40 BP
logitech cordless mouseman
VX900
XP PRO sp1a
PostPosted: Fri Jun 27, 2003 10:31 am
2.75? Put a little effor into it man! On stock cooling you should be able to hit 2.9 with ease!
PostPosted: Sat Jun 28, 2003 9:41 pm
i said i was not even trying,she did even sweet.
why take a chance like that,i expect 2 more years for me out this mach,and then it be my server.
its not like i even need it,that why after2 months i returned it to stock.
i might act like an idot,but i am no fool. :idea:
o.c has an efect on shelf life. :oops:
be sure of that. :wink:
little transistors hate heat. :cry:
this baby is my audy quatro turbo 4x4. :twisted:
and i not going to wail the bag out it at the drag races. :roll:
ati 9700 pro cat3.4
330 entermax quiet
sony 52x
tdk 24x10x40 BP
VX900
XP PRO sp1a
PostPosted: Sat Jun 28, 2003 10:39 pm
Still, if you want life, underclock and use phasecahnge cool it - that's give it loads of run time! As to mine, i don't care for the life - always on the lookout to upgrade - after all, howmany peopple do you know will run their chip at a 700 mhz oc for long periods of time while pushing 20% more voltage than normal thorugh it?
PostPosted: Sat Jun 28, 2003 10:48 pm
so whats the point, :?: to hear tons of fans twirling around :!: :twisted:
ati 9700 pro cat3.4
330 entermax quiet
sony 52x
tdk 24x10x40 BP
VX900
XP PRO sp1a
PostPosted: Mon Jun 30, 2003 4:01 am
Funny, I OC mine above 600MHz more and with the Aquarius II, I don't have to worry about fan noise. :wink:
The Gift of Healing
Conscious Energy Meditation
PostPosted: Sat Jul 12, 2003 3:45 pm
Hey I finally got something worthy of a post for an overclock (well, technically).
Last night I popped my 1.83Ghz XP2500 into the motherboard. Set it at 200x11. Upon boot is recognized it as an XP3100. THe FSA was actually running at 199MHz for a speed of 2.19GHz. Technically its not an overclock in my book as it's the same as an XP3200. I'll post my real overclocks soon 8)
PostPosted: Thu Jul 24, 2003 3:58 am
Iv thought about over clocking a bit more but... it runs so well/cool... why bother.
Cpu: AMD 2500 Barton (1.8) 333FSB clocked over to 2.3
Cpu Runs at 37c ideling 43c with full load with fans on full blast.
MoBo: Asus A7V333-x
Ram: 512 333FSB Corsair
Cooling:(9)80mm fans + (1) 120mm fan case mounted.
Stock Heatsink with 80mm fan mounted on top.
PostPosted: Thu Jul 24, 2003 11:36 am
I managed to get my AMD Athlon XP 1700+ up to an Athlon XP 2000+ not quite as good as Toby's 2200+ though. I raised it 17.6% which means Toby did it 29.4%, nice going.
Dual Boot Windows XP Pro, Linux RedHat 9.0
Intel Pentium 4 630 (3.00 GHz, 800 MHz FSB, 2MB cache)
1 GB DDR2 533 MHz RAM
160 GB 7200rpm SATA HDD 8MB Cache
ATi Radeon X300 SE 128MB PCI-E
DVD-RW
Dual 17" TFT Monitors
PostPosted: Fri Jul 25, 2003 11:07 pm
ahhh. just got new board with good voltage.
now i can find out what my cpu/cooler can do.
am starting small for tonight: 14x/166=2332mhz 1.8v
i will see what kind of damage i can do this weekend and
report back. (2.2volts :twisted: )
