It is currently Fri Sep 18, 2020 10:47 pm
Post new topic Reply to topic  [ 225 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23  Next
PostPosted: Mon Jan 31, 2005 9:00 am
Going through the bios and not using clockgen or other tweaking/oc'ing programs, the hightest stable oc I have been able to achieve is 2.35ghz. This Asus board doesn't allow you to adjust the multiplier or lock the agp/pci so that is a bummer as I believe from all the reading I've done and seeing the results of others that I could reach a higher oc if I had those two options available to me.
Here are the settings:
HTT(Still called FSB in this BIOS) 235mhz
Multiplier X 10
vCore 1.55V
Divider(Memclock to CPU Ratio) 1:1
Temps on the cpu when it is under 100% load remain between 47C to 50C, and at idle, temps will drop to 37C to 40C. I am using a stock hs/f cpu cooler, and Kingston Value Ram @ 3-3-3-8 CAS latency timings with the DDR voltage at 2.6V.
I may be able to reach a higher oc as soon as I get lower CAS latency memory and a better cpu cooler. We shall see. :twisted:
PostPosted: Tue Feb 01, 2005 5:34 am
Well my best so far with my current setup is 9x300Mhz HTT(3x HTT) , 5:4 250Mhz Ram for a nice 2.7GHz, good enough for 31s SuperPi Score to 1M places, but for everyday use I am at 10x250MHz HTT(4X HTT), 1:1
Vcore set to 1.55v
Ram Set to 2.75
Timings are 2.5-3-3-7 1T
Other Notables
P3 [email protected] ( Still running 4 years later )
AMD [email protected]
P4 [email protected]
 Post subject: Over...
PostPosted: Fri May 13, 2005 6:54 am
I am not really an overcloker, but the theme is very hot...
I have just built a computer with an Asrock 4145 GV 5.0 mobo
and a northwood 2.26.
Just for play I moved the fsb to 166, and voilá, the speed of
that little thing went to 2.83 G. flawlessly.
It is surprising, all of that at stock voltage and with only one case fan,
temperature only rised about 4 or 5 degrees C.
All stable, as it is running stock, but I went back to 2.26 and consider that 2.83 is a good safety top for this processor...
 Post subject: Last OCing
PostPosted: Sun May 22, 2005 4:51 pm
Ran CPU-Z wasn't overclocked like I had hoped :( , still runnin at 2.4 no matter what I set it at in the BOIS....Oh well.
My rig
2500 Barton OC'ed to a 3200
1024 mem
120 h/d 8mb buffer
GeForce FX 5600 Ultra 128mb
52X Cd Burner
12X DVD rom
Shuttel AN35Ultra m/b
OS's h/d split half Win Xp Pro half Linux 9.2 Pro :D
PostPosted: Sun May 22, 2005 9:41 pm
right now steady 3.44. highest was 3.53, but I only had it like that long
enough to run 3d mark
DFI Lanparty Venus
Opteron 165 @ 2.8
Thermaltake Big Typhoon
2X1024 G.Skill
ATi 4770
GameXtreme 700W
LG 37" 1080P LCD
Hannspree HW191D widescreen
PostPosted: Tue Aug 23, 2005 5:10 pm
Hi folks scored pretty high with my amd.
Proc amd 2600xp (non barton so i found out)
Cooling thermaltake rated at a 64bit 3400
asus a7n8x deluxe rev 2.0
768 mg legend ddr 400 running at 333mhz anything over 402 and it cracks the nanas
settings.
vcore 1.8v
multiplier 12.5
fsb 184
final result was posting and running smooth as at 2300mhz
core i7 [email protected]
asrock x58 extreme 3
Creative x-fi xtreme gamer
PostPosted: Tue Aug 23, 2005 8:21 pm
hold on there max - this is with your A64 setup?
PostPosted: Wed Aug 24, 2005 5:15 am
That was with the P4. Now with the AMD I am running a steady 2.2. I have
gotten up to 2.3, but I can't get any better that that. I tried changing the
RAM/FSB ratio to 8/10 but that did not help. I think that my ram is pretty crappy
DFI Lanparty Venus
Opteron 165 @ 2.8
2X1024 G.Skill
ATi 4770
GameXtreme 700W
LG 37" 1080P LCD
PostPosted: Fri Aug 26, 2005 12:02 pm
AMD64 3000+, running @ 2.528GHz, RAM @ DDR466 2.5-4-4-10...
Finally got water-cooling!
This is a lie.
PostPosted: Tue Aug 30, 2005 3:07 pm
don't worry max i can't get any higher then 2.3 with my 2600xp (no barton) and thats with $%^[email protected]# legend ram but at 2.3 it was running sweet as.
