What is your highest overclock?
I am now up to 2640 stable through 3dmark 2001se and now running SANDRA a bunch of times.
Abit NF7 vs. 2 (tic tac d23 3dfire bios)
AMD Athlon XP 2500 Mobile @ 2640MHz (221x12) 1.85 vcore
Thermalright SP-97 Vantec Tornado 92mm
HIS 9800PRO ICEQ 128MB 412/365
OCZ EL PC3200 [email protected] 440MHZ
120GB Maxtor
19088 3DMark2001SE score
120GB Maxtor
800mhz overclock.
Got my 2.4 400 bus P4 to 3.2 (533) at stock voltage. 800mhz is not bad considering this is an OEM chip and I'm using an MSI board (645E Max) with PC2100 memory. Haven't really tried to go past 533 since the thing is rock solid and don't want to push my luck. I'm also running my memory at cas 2!
- Pilgrim
- Contact:
- Green Belt
- Contact:
- Black Belt 1st Degree
- Contact:
Hello, noob overclocker here. Just wanted to say I'm quite proud of my 2.353 oc on my socket754 130nm AMD Athlon64 3000+. That is around a 17% gain over the stock 2ghz speed, and on stock hs/f. I posted a screen shot and more info bout it here.
viewtopic.php?t=60633&start=10
Don't want to clutter up the site.
[img]http://i30.photobucket.com/albums/c328/Rabidwerewolf/sigtemplate800x200rd2b.jpg[/img]
- Black Belt 4th Degree
- Contact:
Now at 2.5Ghz and 50C after 3DMark 2001SE
All air cooled with my new invention!
[img]http://i3.photobucket.com/albums/y83/RobPope/sigmove.gif[/img]
[b]Jocuri cu impuscaturi[/b] si alte genuri, pentru toate varstele doar pe [url=http://smarturl.it/jocuri]acest link[/url] - distractie si amuzament garantat!
