It is currently Tue Oct 16, 2018 12:01 am
Post new topic Reply to topic  [ 225 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 23  Next
PostPosted: Sun Nov 16, 2003 1:58 pm
Just remember to tap up the voltage as you go.
PostPosted: Mon Nov 17, 2003 11:14 pm
3.31 and climbing....
PostPosted: Mon Nov 17, 2003 11:17 pm
Keep going peyana. You've got head and volt room left.
PostPosted: Wed Dec 03, 2003 1:22 am
Well heres mine;
I once had the FSB at a default setting of 166 and just raised the multiplier, however after about 4hrs I would get stop errors, mostly USB.sys. Then I lowered the FSB just by 1 to 165 and now the system has run for more than 24hrs at a constant temp and zero stop errors..
Comments are always welcome :wink:
Nightfox PC Asst
_________________________________________________
Current Speed: 2.17Ghz (Default)
MOBO: Abit NF7-S
CPU: Athlon XP2700+ Thoroughbred (Model 8 )
Ram: 512Mbx2 PC2700 CAS ?? Kingston
Cooling: Thermaltake Volcano 11+
BIOS Settings: 166MHz FSB/13x multiplier/CAS ??, Vcore 1.65
**CPU Throttling: Disabled
**FSB Throttling: Disabled
**Enhanced PCI: Enabled
**System Temp: 25*C, CPU Temp: 35*C, Room Temp: 78*F
Current Speed: 2.32Ghz
MOBO: Abit NF7-S
BIOS Settings: 165MHz FSB/14x multiplier/CAS ??, Vcore 1.75
**System Temp: 30*C, CPU Temp: 45*C, Room Temp: 78*F
Well so far thats my highest I think i can go...doing some more testing that peanya suggested...I will let you know.
AMD Athlon XP (T-Bred Core) 2700+ FSB 333
Antec 430w Truepower PSU
Avus Premier Case
Abit NF-7S Rev 1.2
9700 AIW ATI Video
120 Maxtor HD
Plextor DVD-R/RW
Audigy 2
Kingston 512 DDR x2
 Post subject: Im back with great news!
PostPosted: Wed Dec 03, 2003 10:21 pm
Okay I did as Peanya suggested and this is the great news.
First I did what peanya said to do with the memory:
7 > 8 -- Row-Active Delay
2 > 4 -- RAS-to-CAS Delay
2 > 4 -- Row Precharge Delay
2.0 > 3.0 -- CAS Latency Time
THen I changed the DDR volatage 2.7 from 2.6
Then I changed the FSB to 210 and Multiplier to 11
And heres the results with the burnin test.
Zero errors and full stability. System is 25* C and CPU temp 40* C
Heres some pictures to show it;
{Images removed} Located below :D
WOOHOO!! Running at 2.32 Mhz... and going strong
PS Sorry for the HOT Pink visual, I was working on a style and messed up the HUE ...LOL
Laters
NF
Avus Premier Case
Abit NF-7S Rev 1.2
9700 AIW ATI Video
120 Maxtor HD
Plextor DVD-R/RW
Audigy 2
Kingston 512 DDR x2
Last edited by nightfox_pc_asst on Thu Dec 04, 2003 12:25 am, edited 1 time in total.
PostPosted: Wed Dec 03, 2003 11:44 pm
fortune city won't let you hotlink. look at one of the sites here - http://www.motherboards.org/forums/view ... hp?t=33865 and upload to them.
PostPosted: Thu Dec 04, 2003 12:18 am
Thanks for that tip. I can see it on my computer, but I guess others can't..
Okay thanks for that...Does my avatar show up??
NF
Avus Premier Case
Abit NF-7S Rev 1.2
9700 AIW ATI Video
120 Maxtor HD
Plextor DVD-R/RW
Audigy 2
Kingston 512 DDR x2
yeah. it's just fortunecities that won't allow hotlikinking
PostPosted: Thu Dec 04, 2003 12:21 am
The image from another site, Let me know if this shows up or not?
Thanks all
NF
Avus Premier Case
Abit NF-7S Rev 1.2
9700 AIW ATI Video
120 Maxtor HD
Plextor DVD-R/RW
Audigy 2
Kingston 512 DDR x2
Last edited by nightfox_pc_asst on Thu Dec 04, 2003 12:24 am, edited 1 time in total.
PostPosted: Thu Dec 04, 2003 12:22 am
without the spaces, it looks something like this right /\ - don't put any space between the end of the filename and the last box.
