AGP adjusment for a giga-byte GA7-VRXP ???
Postby whale » Tue Jun 11, 2002 9:50 am
i have recently installed a new board ga7-vrxp into my system and i can't find any place to adjust agp volts, ( not in bios either ). i'm currently running a voodoo 5-5500 :oops: and i would like to run it up a little bit :twisted: but don't know where to go and do it . i've look on the giga-byte site and don' t find any info there :x . any help at all would be highly appreciated :D . got to make this go just a little bit faster :!: :twisted:
whale
Postby Toby B. » Tue Jun 11, 2002 7:32 pm
Settings should be in the manual. Do you have a manual?
Toby
Toby B.
Postby whale » Thu Jun 13, 2002 2:57 am
yes i do have manual and it shows to be adjustable in the bios, but there is no listing for it in the bios.
whale
Postby cangove » Fri Jun 14, 2002 3:02 pm
Yes, its adjustable throught he BIOS (at least if you are using F6 the latest bios). Go into BIOs and select "Hardware Monitor & MISC Setup". The third setting down is AGP Voltage and is modifiable.
cangove
