RESTARTING TROUBLE
RESTARTING TROUBLE
Postby ^Steel » Tue Jun 11, 2002 2:41 am
k i av a amd athon 900 and recently baught some new stuff so i could increase the fsb this being Abit KX7, 256 Crucial RAM PC2100. I increase the the fsb to 166 and put the multiplier down to 6, increase voltages to:
Core 1.85
DDR 2.75
Now my computer stays on for a while but restarts inself at random times, has anyone else had a similar problem or can help? :?
Not sure if its hardware or software related atm, im guessing hardware. HELP!!!!!!! :)
^Steel
Postby Toby B. » Tue Jun 11, 2002 7:40 pm
random reboots - sounds like to me that its is an overloaded or failing power supply To test an ATX or newer style power supply voltage on the red wire should be 5V according to Hardware Junkie. - you will need a digital multimeter.
Hope this helps
Toby
Toby B.
