It is currently Sun Jan 19, 2020 9:59 pm
PostPosted: Fri Jan 26, 2018 8:07 am
Hi,
Have some Hi Performance Corsair DDR2 memory and am wondering if any Intel DDR2 desktop motherboards can be overclocked?
Searched forum using Intel desktop motherboards but got "Search found 0 matches: Intel desktop motherboards"
Also Googled using Can Any DDR2 Intel Desktop Motherboards be Overclocked got > 7 Million hits Started checking but found nothing relevant
Thanks
Ken
PostPosted: Fri Jan 26, 2018 10:56 am
"any" is a little vague...
in theory, sure every board can be. the trick is whether it's really supported and if the board is designed to handle it.
do you have a board you're trying to use with the memory?
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Sat Jan 27, 2018 10:23 am
Hi Roach412,
"do you have a board you're trying to use with the memory?"
Yes it is a Intel Desktop Board D945GNT https://www.intel.com/content/www/us/en ... oards.html
Reason for asking is from my limited experience it seems to handle more different DDR2 timings than my Dell, HP or IBM PCs.
I have No experience in OverClocking so am interested in any suggestions...
Thanks
Ken
PostPosted: Mon Jan 29, 2018 8:49 am
my understanding is that the D945GNT boards really aren't designed for overclocking - I think most of the types of settings used for overclocking are locked in the BIOS. I don't believe you can alter the board voltages(1.8v) - which can significantly limit your options.
getting the highest clocked memory you can from the QVL is probably your best option, in my opinion.
-R
