It is currently Thu Oct 18, 2018 3:17 pm
 Post subject: Temperature confusion
PostPosted: Sat Apr 05, 2008 7:38 pm
What from the following is most recomended to trust the most in terms of actual cpu temp. Riva seems to be off a good 8 degrees from the other two. I'm thinking it's actually reading the mb temperature.
Rivatuner plug in
pc probe
asus ai xp executable
PostPosted: Sat Apr 05, 2008 10:53 pm
The BIOS is the most accurate reading, and even then it can be + or - 10 degC out... You always have this issue when a hardware device meets software.. If manufacturers opted for accuracy on that, motherboards would cost a lot more... All the software probes in windows have to take their readings from the same hardware as the BIOS, couple that with stuff running in the background and you increase the inaccuracy.. Best bet for accurate temp. readings is to use hardware devices with hardware reading, ie a dedicated thermometer...
PostPosted: Wed Jul 09, 2008 11:34 pm
CoreTemp for any cpu's with 2 or more cores is i would say dead on accurate.
Intel Core 2 Duo E6750 3.8ghz
8800 GTS 640MB
Crucial Ballistix 2GB DDR2 800
Gigabyte DS3R
PostPosted: Sat Jul 19, 2008 5:05 am
These are the 2 programs I use.................. 8)
http://www.alcpu.com/CoreTemp/
http://www.techpowerup.com/downloads/1080/Real_Temp_2.60.html
