It is currently Fri Dec 14, 2018 8:37 pm
 Post subject: Memset help?
PostPosted: Tue Feb 26, 2008 3:33 am
Anyone successfuly used this prog on an AMD64 system?
I have no problem running it from the desktop, does everything I ask, but when it loads on boot my system locks up.
This is what MemSet.ini from the MemSave directory says:-
[MS875]
AN=1
1A=2
2A=1
3A=1
4A=11
5A=1
6A=1
7A=0
8A=0
9A=0
10A=0
11A=1
12A=0
13A=2
14A=3
15A=7
16A=5
17A=1
18A=3
19A=7
20A=10
21A=1
22A=2
23A=1
24A=1
25A=1
I believe it's the first line that is causing me the hastle, I think it points to an intel chipset. Anyone seen this, heard of this, found and cured the problem themselves?
I particularly want to change 'Read/Write Queue Bypass' and 'Queue Bypass Max' cos I can't do it in the bios. Tried versions 3.4 and 3.5beta.
And I don't want to join any more forums just to post a problem.
PostPosted: Tue Mar 11, 2008 7:18 am
http://www.tweakers.fr/memset.html
there's no need to join that forum. It looks like some people got it to work then again I could be mistaken.
