It is currently Fri Jan 18, 2019 8:15 am
PostPosted: Sat Jan 19, 2008 10:03 pm
INTEL Core 2 Duo 3.00 GHz 1333 MHz 775 6MB Desktop Processor Retail ***Free Shipping***
ZipZoomfly Part#: 10007603
Manufacturer SKU: BX80570E8400
Our Price:
$229.90
INTEL Core 2 Duo 3.00 GHz 1333 MHz 775 6MB Desktop Processor Retail at ZipZoomfly
Overclocked Retail E8400 --> LINK:
THRASHER2's benchmark scores
Project T2's Spinner Case
PostPosted: Sat Jan 26, 2008 12:43 pm
<gulp>
5Ghz? (later in the thread) 8O
RIAA vs The People
PostPosted: Sun Jan 27, 2008 4:07 am
Check this out......
PostPosted: Sun Jan 27, 2008 4:28 am
Mr T wrote:
I just got in to water cooling. Don't be putting ideas in my head. :lol:
RIAA vs The People
PostPosted: Sun Jan 27, 2008 10:32 am
Saw a similar thing years ago on an XP1700... They got a few Ghz out of it... :lol:
PostPosted: Sun Jan 27, 2008 10:52 am
I fail to see the attraction of mixing live electronics and water. Spend $2000 on a new system and then blow it up :? It seems a bit retarded to me.
PostPosted: Sun Jan 27, 2008 11:10 am
Some positives:
1.) Quieter
2.) Cooler temperatures
3.) More efficient (less power required)
It will not "blow up". It will not short circuit or anything like that. For one, you always let your loop operate for at least 24 hours before putting it in your case, to check for leaks. Then, in the unlikely even you get a leak, you use non-conductive fluid. Even if my radiator sprung a huge leak and dumped it's fluid all over my PSU and motherboard (which are right below), my PC would be fine. Just dry it off, get a new radiator, and continue on with life.
Leaks are very uncommon in a liquid cooling setup (water cooling is a misnomer, as most don't use water at all). So you have nothing to worry about. The fluid I'm using was demonstrated by having a "bath" of it, and then dumping the motherboard et al into the fluid. The PC kept operating and was none the wiser.
RIAA vs The People
PostPosted: Sun Jan 27, 2008 11:19 am
Sabrewings wrote:
[(water cooling is a misnomer, as most don't use water at all)
Well that makes sense. The phrase "water cooling" is very misleading.
PostPosted: Sun Jan 27, 2008 11:47 am
and that 90% of all liquid cooling mistakes and disasters that occur in the first couple days are a direct result of ignoring the manual or not following the manufacturers recommendations for cooling liquids...
PostPosted: Sun Jan 27, 2008 3:51 pm
These two kits are simple and easy to use ;)
Swiftech H20-220 Compact Liquid Cooling Kit
http://www.swiftnets.com/products/H20-120-COMPACT.asp
http://www.swiftnets.com/products/H20-220-COMPACT.asp
