It is currently Mon Apr 22, 2019 2:25 am
 Post subject: T2 Goes Water-Cooled
PostPosted: Thu Dec 20, 2007 8:13 pm
Is you heard it :haha: T2 is finally going water cooled.
I will be making a Water Cooled Bench Station for OC'ing and Benching.
The tech Station will have Swiftech Items :thumbsup:
1xApogee™ GTX water-block
1x MCP655™ pump With a speed controller (part # MCP655)
1x MCRes-Micro
1x MCR320-QP (Quiet Power™) Radiator
3x
Cooler Master Y720CCD-25K1-GP 120mm Silent Fans
10ft of
Tubing: 1/2 in. (ID) x 3/4 in. (OD) Clearflex Vinyl Tubing
Cooling a X6800 CPU on a BFG 680i motherboard
Here is a Quick Draft :pimpin:
More to Come :evil:
THRASHER2's benchmark scores
Project T2's Spinner Case
PostPosted: Thu Dec 20, 2007 8:16 pm
Here are the Fans
Fans mounted
Test Setup
Added Bling :evil:
PostPosted: Fri Dec 21, 2007 5:35 pm
Temp print screens coming :tongue:
PostPosted: Fri Dec 21, 2007 6:11 pm
Ideally in a watercooling setup the pump should go straight to the radiator to be sure it removes any residual heat it dumps into the fluid before it gets to the cooled parts.
RIAA vs The People
PostPosted: Mon Dec 24, 2007 1:34 am
Hummm Ok :D
This was my first water cooled setup PDT_Armataz_01_01
I will try to change the Lines around :wink:
PostPosted: Mon Dec 24, 2007 1:35 am
Some Scores...........
PostPosted: Mon Dec 24, 2007 8:35 pm
Nice job so far. In case I wasn't perfectly clear earlier, this is the optimum setup for watercooling...
  • reservoir
  • pump
  • radiator
  • CPU
  • other cooled parts in your preferred order
  • back to reservoir
A larger reservoir the better, as it will give the fluid time to cool even more before being sent back in to the loop.
(I've been quietly toying around with watercooling for a good while now. Ready to put the finishing touches on my new build soon and unveil it... 8) )
RIAA vs The People
PostPosted: Sat Dec 29, 2007 10:30 am
I've setup my passive water coooling so that the pump pulls the warm water from the blocks then dumping it to the reservoir before it gets to the rads to be cooled further more and then pushes the cooled water from the rads to the blocks :wink:
Image Image
PostPosted: Sat Dec 29, 2007 10:43 am
Similar concept, but depending on the pump it will probably work better when the pump is pushing, not pulling.
RIAA vs The People
PostPosted: Sat Dec 29, 2007 11:05 am
Yeah as it is mostly setup that way but using a bigger and more powerful pump (I have the eheim 1250) would pretty much be more flexible such as extracting the heated water off the blocks quickly (well that's just a little theory I wanted myself to believe LOL)
Anyway... as long as you don't put the pump right before the blocks to dump water directly to the blocks... he should be fine :)
Image Image
Users browsing this forum: BLEXBot [Bot] and 1 guest
