Editing GeForce 5900xt BIOS - Can't change memory clock
Post Reply
Bolgan
Post by Bolgan »
I've been overclocking my 5900xt without any problems using coolbits.
I want to permanently change the setting by editing the bios with NiBiTor.
I can edit the bios and flash the card, but any program I using to check the clock speed says the memory is running at 400MHz instead of the 450MHz I change the bios setting to. But the GPU is running at the 500MHz (from 390Mhz) I set it to.
The video card is a XFX GeForce 5900xt.
sbrehm72255
Post by sbrehm72255 »
Can you attach a copy of the bios here so I can take a quick peak at it, I've never had a problem editing video bios and reflashing them before, it sounds kind of strange that the one setting took and the other one not.
Are you using the most current version of NiBiTor?
Post Reply
