It is currently Sat Dec 15, 2018 1:26 pm
PostPosted: Mon Nov 12, 2007 7:08 pm
I have not the slightest clue on how to do it, how much I can do it before it blows up. Could someone point me in the right direction?
PostPosted: Wed Nov 14, 2007 6:53 pm
start by increasing the fsb by tiny increments like 5mhz and then bootin into windows and running something like prime 95, 3dmark 06 or super pi to test for stability. You should be able to get to around the 3.6ghz or so mark using the stock cooling and keeping good temps, without increasing the vcore. Bear in mind that you will also need good memory that overclocks also
core i7 920@4.0ghz
asrock x58 extreme 3
Creative x-fi xtreme gamer
PostPosted: Wed Nov 14, 2007 7:01 pm
OK....I've actually got a Zalman 9500 big-a$$ fan on that chip, and I have Crucial Ballistix Tracer memory...you think I can hit 3.6 no worries?
