It is currently Fri Jan 18, 2019 3:48 am
PostPosted: Thu Oct 11, 2007 3:15 pm
Can I completely change all the RAM to PC5300 on a mother board that might only require PC3200, or visa versa
PostPosted: Thu Oct 11, 2007 4:39 pm
What is the Manufacturer and Model of the motherboard?
PostPosted: Thu Oct 11, 2007 6:07 pm
PC3200 is DDR. PC5300 is DDR2. Not interchangeable.
RIAA vs The People
PostPosted: Sun Oct 14, 2007 10:06 pm
Thanks, everybody, this is just a question in general.
Just wondering can I use faster RAM, if they're compatible, of course.
PostPosted: Mon Oct 15, 2007 7:04 pm
You can, but the memory will only work at the motherboard's fastest supported speed.
RIAA vs The People
