Limited Network Connectivity caused by spyware
Help and Discussion
Postby dve83 » Wed Mar 16, 2005 2:50 am
I had this problem after NewDot.Net and another item (cant remeber name but it was a 4 letter abbreviation -> almost like "VNSS").
I deleted the newdot.net folder from Program Files and removed the startup items with MSCONFIG. Thereafter I used HijackThis to removed another entry of NewDot.net.
I was required to run a utility called Winsockfix for WIndows XP and it rapaired the Winsock.dll file and the network connection.
Just thouht id share the info
cheers :)
-dve83- Folding for 33258
Gigabyte GA-MA69VM-S2,AMD Athlon X2 5200+, 6GB DDR2-800, Seagate 250GB 7200 RPM, Western Digital 1TB 7200RPM,
460W Coolermaster PSU, Windows 7
"Perhaps it's not paranoia. Perhaps it's just finesse." - dve83
dve83
Postby evasive » Wed Mar 16, 2005 10:53 am
Normally you need to run the uninstall from Add/remove software, newdotnet has an entry in there. Afterwards you can clean off the sleeping remnants with lavasoft ad-aware and spybot search&destroy.
Postby dve83 » Wed Mar 16, 2005 10:27 pm
hi, yes sorry, your absolutely right.I later read that there is indeed an entry in Add/Remove Programs list.
:oops:
However, I wasn't lucky enough when running adware and spybot to have the rest removed (mine simply didn;t pick up any items, and it was fully udpated) , so I had to do it manually.
dve83
