Anyone recently get a new MS update?
Help and Discussion
Postby ThEvil0nE » Sat Mar 12, 2005 4:16 pm
Oylpann wrote:Thanks alot for the info Evil. That clears things up. :)
NP bro :wink:
Image Image
ThEvil0nE
Postby ThEvil0nE » Sat Mar 12, 2005 4:18 pm
EmilyB wrote:
evasive wrote:
snap355 wrote:Not all updates require reboots
not all reboots require an update either :lol:
:lol: :lol: :lol:
not all updates and reboots are required too :roll: ummmnnn... ok I'm confused :? LOL
j/k
:lol:
Image Image
ThEvil0nE
Malware Removal Tool a run-once application KB890830
Postby Petey970Z » Sun Mar 13, 2005 2:57 am
Windows Malicious Software Removal Tool - March 2005 (KB890830)
After the download, this tool runs once to check your computer for infection by specific, prevalent malicious software (including Blaster, Sasser, and Mydoom) and automatically helps remove any variants found. After it runs, the tool is deleted from your computer. A new version of the tool will be offered every month. If you want to manually run the tool on your computer, you can download a copy from the Microsoft Download Center or run an online version from microsoft.com. In addition to using this tool, you should use an up-to-date antivirus product to help protect your computer from other malicious software.
Help and support
http://go.microsoft.com/fwlink/?LinkId=39987
This little app is a run-once and it will come each month to your nearest computer and check for schnolleyghaasters and sech.
Petey sends......
Petey970Z
Previous
