Quick Question
Help and Discussion
Quick Question
Postby audiobliss » Wed Mar 02, 2005 9:36 am
Can I run two scans simultaneously? I just downloaded Spy-Bot and Ad Aware....can I let them both scan at the same time?
Thanks!
audiobliss
Postby Toby B. » Wed Mar 02, 2005 9:41 am
Run one or the other. If you run both there is a tendency for one program to interfere with the other...
Toby B.
Postby audiobliss » Wed Mar 02, 2005 9:43 am
Ok; I'll run one after the other. Thanks!!
audiobliss
Postby audiobliss » Wed Mar 02, 2005 9:49 am
I just ran SpyBot and it found a few 'problems'. Should I just delete everything it found, or should I go through everything to see what it is?
audiobliss
Postby Oylpann » Wed Mar 02, 2005 10:06 am
Theres a possibility that ripping everything out that spybot found could cause some software issues, but chances are, if it messes up the software, your better off without that program anyway. :wink:
I've never had any issues with Spybot, Ad-Aware, or the MS AntiSpyware applications removing anything that it shouldnt.
Asus F2A85-V Pro
AMD A10-5800K APU @ 4.5GHz
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
Oylpann
Postby ~PJ~ » Wed Mar 02, 2005 10:16 am
Except that they tend to see each other's logfiles as Spyware...
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start.
~PJ~
Postby audiobliss » Wed Mar 02, 2005 10:37 am
Ok, now I have a problem. I'm typing this on my laptop as my desktop is now locked-up. I told it to just go ahead and delete everything it found. Seemingly after it did that, all these error windows popped up and told me that 'componenet missing' and, umm...well...how quickly we forget....but there was also another one...lol. I had to close about a dozen or so of these windows. And now, my computer is locked up. I'm guessing ctrl+alt+delete would take care of it, but I haven't done it yet.
Any idea of what happened?
Thanks.
audiobliss
Postby audiobliss » Wed Mar 02, 2005 10:40 am
Ok, update. I clicked on the taksbar and it seems that there was a window hiding behind SpyBot...so it wasn't really locked up. This window says
Some problems coudn't be fixed; the reason could be that the associated files are still in use (in memory).
This could be fixed after a restart.
May Spybot-S&D run on your next system startup?
And I remembered that most (if not all) of the files causing the error messages were '.dll' files; whatever they are.
Thanks!
audiobliss
Postby colinJohn » Wed Mar 02, 2005 11:25 am
click yes, then re-start
when it starts it'll carry on cleaning. It'll take a while.
Then run the other spyware programme
Don't worry if it all goes pear shaped - at worst you do a system restore.
"It's the best that there is"
colinJohn
Postby audiobliss » Wed Mar 02, 2005 11:48 am
Ok, will do. Thanks!!
audiobliss
