trojan question
Help and Discussion
trojan question
Postby sloopdog 1 » Sun Feb 20, 2005 6:14 pm
what is this?>>>>>>>>Trojan horse TR/Dldr.Agent.fy
where does it come from?
thanx. :!:
No keyboard detected-Press any key to continue.
sloopdog 1
Postby EmilyB » Mon Feb 21, 2005 1:26 am
It nasty spyware, and you need to get rid of it.
From the "Dldr" part of the name, it maybe some sort of dialler for hijacking your internet connection.
You need to run some anti-crapware tools and get rid of it.
EmilyB
Postby Toby B. » Mon Feb 21, 2005 2:33 am
Dldr = Dowloader
You should be able to get rid of it easily by updating your virus definintions.
Might try Mcafee Stinger as well
Toby B.
Postby kltsin » Mon Feb 21, 2005 11:17 pm
It looks more like malware.
Its definetly a downloader that installs adware.
There are many means of infection, through an open port, a BHO or various scripts....
Once you find the files, generaly random named files running, they can be stopped then deleted.
Run with updated defs for all of your AV, but mostly anti-spyware programs such as adaware and spybot or others that you use... Do this in safe mode for best results and disconnect from the internet.
I dont know anything about this new FY varient but its definetly from the same family of downloaders....
kltsin
Postby sloopdog 1 » Tue Feb 22, 2005 3:53 pm
Antivir got rid of it right before I posted question.Just wanted to know what it was.Seen it before.Not quite sure where I pick it up at.I run adaware and spybot several times a week.hijack this also.
ccleaner has new update.seems to be More efficent. love it. :D
sloopdog 1
Postby snap355 » Tue Feb 22, 2005 5:10 pm
Good thing you caught the nasty bug
[/url]
snap355
Postby ThEvil0nE » Tue Feb 22, 2005 5:36 pm
sloopdog 1 wrote:Antivir got rid of it right before I posted question.Just wanted to know what it was.Seen it before.Not quite sure where I pick it up at.I run adaware and spybot several times a week.hijack this also.
Be it known that AntiVir is one of the most agressive scanners out there, this is good but sometimes gives you a false alarm of security.
I'm using avast! which is a very good scanner and almost fool proof (nothing is fool proof, only updated scanners are our best defense)
http://www.avast.com/index.html
I highly recommend avast! to everyone. avast! unlike other virus scanner has technical support I'm running 2 antivirus programs at once with no issues at all, avast! and EZ by Computer Associates, EZ has not tech support. avast! btw has a built in "speech engine" which is cool and you can visualy know that avast! is working by it's revolving active icon everytime you open your browser, open a folder or right about anything you'll do, give you the secure feeling knowing your anti-virus program is working 8)
Image Image
ThEvil0nE
