Microsoft Anti-Spyware incompatible with Windows 2000 Pro?
Help and Discussion
Postby mr newbie » Wed Feb 16, 2005 2:22 pm
Tried installing it on two IBM T20 ThinkPads running 2000 Pro. Each time, install triggers a restart that gets locked up in boot doing a "Drive Check". I have to F8 into safe mode to remove the application so the laptops will boot normally to Windows. Anybody else run into this problem?
On a side note, one of the lappys I just converted over to Windows XP yesterday and the conflict with Anti-Spyware is gone.
Mike
Asrock N68PV-GS mATX
Athlon X2 5050e Brisbane
4GB Kingston DDR2-800 (2X2)
120GB Seagate Momentous 7200.2
Sapphire HD4650 512MB (DDR2)
Hec HP585D 585W psu
Windows 7 RC
mr newbie
Postby Oylpann » Wed Feb 16, 2005 2:28 pm
I think you have to be a "registered XP user" to use the anti-spyware.
Asus F2A85-V Pro
AMD A10-5800K APU @ 4.5GHz
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
Oylpann
Postby mr newbie » Wed Feb 16, 2005 2:40 pm
Oylpann wrote:I think you have to be a "registered XP user" to use the anti-spyware.
Ahhh :idea: So it is only meant to work on XP.
Thanks,
Mike
Hec HP585D 585W psu
Windows 7 RC
mr newbie
Postby EmilyB » Thu Feb 17, 2005 12:39 am
Thanks,
Mike
Not exactly.
Microsoft Windows AntiSpyware (Beta): System requirements
Published: January 6, 2005
Related Links
• Beta overview
• Frequently asked questions
• Download the beta
Minimum system requirements for Windows AntiSpyware (Beta):
• Microsoft Internet Explorer 6.0 or higher
• A 300 MHz or faster processor with at least 64 MB of RAM
• Microsoft Windows 2000, Windows XP, or Windows Server™ 2003
• At least 10 MB of available free space on your hard disk
• Internet access with at least a 28.8 Kbps connection to use SpyNet™
Click me
EmilyB
