how clean a virus on motherboard
Help and Discussion
Postby skotperez » Sun Feb 13, 2005 10:49 am
hi everybody,
my motherboard has found a virus, i guess
after the RAM memory test when i start my computer i can read:
Trend ChipAwayVirus (R) on Guard Ver 1.63A
where can i find an antivirus for my motherboard? and how can i clean it?
thanks,
alfonso
skotperez
Postby EmilyB » Sun Feb 13, 2005 10:54 am
:mb_welcomeMB::
skotperez wrote:after the RAM memory test when i start my computer i can read:
I think this is just a standard POST message telling you, you have this feature active on your motherboard. "Trend" is certainly an antivirus vendor.
If not, have you tried clearing your CMOS via the motherboard jumper?
EmilyB
Postby Copper » Sun Feb 13, 2005 11:29 am
its a standard bios message. its to tell you you boot files on you hardrive are protected againts boot sector viruses to stop your harddrive being wiped, by those nasty little buggers. nothing to worry about
Copper
Postby skotperez » Sun Feb 13, 2005 12:10 pm
i have done. i clean with the jumper and the message appears again but the red box don´t. i hope the virus has gone.
thanks.
skotperez
Postby snap355 » Sun Feb 13, 2005 5:01 pm
Whatever you do, don't put in the dishwasher :wink:
[/url]
snap355
Postby kltsin » Mon Feb 14, 2005 2:14 am
skotperez wrote:i have done. i clean with the jumper and the message appears again but the red box don´t. i hope the virus has gone.
thanks.
Possibly you or we are confused.
Trend is the antivirus boot watch utility, it posts each time saying if there is an issue or not.
Now what about this little red box? Is trend saying there is a boot virus? If so which one?
Do you need a antivirus program?, if you dont have one you need one, i would assume you would have trends pccillin, but that may not be installed.
If you have no other AV product installed download the free AVG from here; http://free.grisoft.com/freeweb.php/doc/2/
kltsin
