AVG 7.0 Anti Virus
Help and Discussion
Postby kltsin » Mon Feb 14, 2005 1:06 am
evasive wrote:ah, forgot the basics. oh well, still can't hurt to check firewall settings...
Cant forget the basics Evasive... we know Tobys under a Mountain of stuff with projects... easy to slip up on minor things...
BTW; Evasive Im Keith, aka kltsin, nice to meet you again; just wanted to be a bit more personal.. (appreciate your site very much :D ).
kltsin
Postby Mark H » Fri Feb 25, 2005 2:41 pm
Just for the heck of it, I tried MS Antispyware, and it found 3 trojans that McAfee missed. So, I disabled McAfee, installed AVG 7, ran a scan, it found 1 virus (in NASCAR Thunder 2004).
My question is: can I run McAfee Firewall with AVG? (currently using MS Firewall......I know, I know)
Mark H
Postby snap355 » Fri Feb 25, 2005 2:59 pm
Yes you need firewall and antivirus and anti spyware and....
[/url]
snap355
Combining anti-virus programs
Postby lannaheim » Fri Feb 25, 2005 5:06 pm
Ah, but what does the wisdom say about running AVG WITH Norton AV? Is that acceptable? So far, it seems as though one or the other will come up with a preemptive message.
Outside of a dog, a book is man's best friend. Inside a dog, it's too dark to read.
--- Groucho Marx
A member of Folding Team number 33258 for a cure for PARKINSONS DISEASE
lannaheim
Postby colinJohn » Sat Feb 26, 2005 2:29 am
The general advice is to only have one virus guard installed - but I've heard that it can be ok if you're lucky and choose the right ones. I've never tried it personally but often wanted to just to see what happens.
"It's the best that there is"
colinJohn
Postby evasive » Sat Feb 26, 2005 4:44 am
McAfee and anything else will bite. Norton and anything else will bite. Don't know of combos between other producers...
Postby bay_bytes » Sun Feb 27, 2005 3:58 am
It also depends on the engine involved, the general rule of thumb is only one AV at any time, AV can work with anti spyware just fine.
Also the new mcafee engine is actually heralded as a very good one so far.
As many viruss attack norton and mcafee past engines this may be a revolution of sorts... time will tell.
bay_bytes
Previous
