It is currently Mon Jun 17, 2019 7:06 pm
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Tue Jun 15, 2004 7:20 am
http://vil.nai.com/vil/content/v_126242.htm
http://securityresponse.symantec.com/av ... .b@mm.html
Quote:
Searches the drive for the files or folders that belong to known security and/or Symantec products.
If a file is found, a copy of the worm will overwrite it.
If a folder is found, a copy of the worm will overwrite all the files with the .exe extension in any subfolder.
The worm will overwrite the .exe files in the following folders, including the subfolders:
C:\Program Files\Symantec
C:\Program Files\Norton AntiVirus
NOTE: The worm is not limited to the above folders, and may overwrite the files in other locations.
Some games are killed (NHL2004) and even wireless network card utilities (Sitecom WLAN adapter).
This one is a real PITA because of the damage it does.
PostPosted: Wed Jun 23, 2004 11:48 am
Some additions to the original post:
Cool WWW Search tool called CWShredder
http://www.spywareinfo.com/~merijn/cwschronicles.html
More than just a useful program, the forums here help kill all the varients of CWS out there. CWS is by far the worst and most propigated spyware I know of.
Great free personal firewall
http://smb.sygate.com/products/spf_standard.htm
A large robust spyware tool (pay) -- Only needed for the most paranoid. No spyware program is perfect (read: complete) yet, so running multiple programs is the only way to get rid of everything.
http://www.pestpatrol.com/
PostPosted: Wed Jun 30, 2004 10:49 am
adding another good link...
http://www.subratam.org/
found this one after learning to confront n'case, 180 solutions, and other bad stuff.
i used the peper killer, and it seemed to do the job.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Fri Jul 09, 2004 8:39 am
spyware blaster 3.2 has just been released
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Fri Jul 09, 2004 8:52 am
Updated. Thanks for the heads up bdub :wink: :D
PostPosted: Sun Aug 15, 2004 3:24 pm
New version of adware availible
Adware S.E
PostPosted: Mon Aug 16, 2004 12:46 am
I believe you meant Ad-Aware and not Adware as Ad-Aware is working/fighting against Adware and other stuff .
Ad-Aware SE is available and reached at least Version 1.03 .
Signature support for the older Ad-Aware 6.181 may cease to exist in the future so better upgrade to the new version .
Do not forget to use Ad-Aware with Spybot as Tandem-Software - two fighters together are better than only one of them
Collected Links against Virus/Spyware and other Malware
Rebels Haven Computer Forum
PostPosted: Mon Aug 16, 2004 7:59 am
thanks Denniss
 Post subject: whats the best
PostPosted: Sat Oct 02, 2004 2:39 am
What is the best free anti virus and fire wall programs Denniss.
PostPosted: Sat Oct 02, 2004 3:33 pm
I'd say Kerio/Sygate for Firewall
Antivir Personal is good as well as some other free scanner like from Avast - maybe Kapersky has a free version,too but I don't know
