It is currently Fri Feb 21, 2020 11:48 pm
 Post subject: ccleaner new version...
PostPosted: Mon Aug 06, 2018 12:47 pm
anybody know how to stop the monitoring agent from showing up in the system tray every time the computer is logged onto. I've turned it off in msconfig, but it always returns.
this is under win7.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Tue Aug 07, 2018 9:28 am
Use the 'msconfig' command to see what else causes it to return. Likely a second executable file for the program, like 'show icon' or similarly worded.. The Task Manager has the 'services' tab that shows all. Look at file names in the program directory, see what has an 'exe' tag name.
PostPosted: Sun Aug 12, 2018 4:27 am
yeah, I tried all of that. none worked. ccleaner always came back in the system tray at a reboot if you had run ccleaner during the last session. it always re-appeared in msconfig as an active service at startup.
so I checked at piriform website, and noticed that they reverted the latest version that they had available back to 5.44. uninstalled 5.45, dl'd 5.44, installed, and no more problems with being able to turn off system monitoring.
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Sun Aug 12, 2018 8:25 am
Thanks for the tip on clearing that annoyance.
Have the same problem with a printer program, had to take out 4 'start up' features. But if you use the printer, then the SysTray icon comes back.. and you have to "end task" on it!
Some programs are like circus barkers.. touting beyond real needs.
PostPosted: Thu Sep 06, 2018 8:22 pm
just an update... ccleaner has a new version now that takes that whole system tray component out of the picture unless you enable "smart cleaning"... so all is good.
my main rig...
asrock 970 extreme3
antec neo he 650r
