About to blow my comuter up!!
Help and Discussion
Postby Toby B. » Thu Jul 09, 2009 1:28 pm
Since joining facebook and "downgrading" <--- HUGE bit of arcasm meant ti IE8 I am getting slammed with viruses/trojans/malware galore. AVG 8.5 is about freaking useless. goes for about 12 hours a scan and does not clean/move a damned thing...
Everytime I blink my eyes I am seeing some form of _______________ 2009 crap pop up in my face.
Malware Bytes wont open, Spybot wont open....
Toby B.
Postby fussnfeathers » Thu Jul 09, 2009 2:00 pm
Ahhhhh you got THAT one. Do a search for Antivirus2009, you'll find removal instructions. It's a nasty one......your task manager won't open either, will it?
http://www.pchubs.com/blogs/antivirus-2 ... ivirus2009 has a pretty thorough removal walkthrough, and a free little utility that helps, although other pages detail it a little further so you don't need a removal tool.
Faster than the speed of snot
fussnfeathers
Postby Mr T » Fri Jul 10, 2009 12:19 pm
Boot into safe mode and run Malwarebytes and Superantispyware from there...
Postby Toby B. » Fri Jul 10, 2009 1:18 pm
Mr T wrote:Boot into safe mode and run Malwarebytes and Superantispyware from there...
Tried that. The system was in near lock down. Crap that should have worked didnt. After about 5 rounds of destroying things with HJT, I got it so avg would run but that was a friutless waste of time as it never really cleaned what it said it did.
I picked up a Computer Associates AV/Spyware program from a local shop, which I was able to get for free..... Now things are working again for the most part. Still more work to do on it but its getting better.
Ultimately I gave AVG the old heave ho..
Toby B.
Postby TriAngle » Mon Jul 13, 2009 7:03 am
TobyB,
I am running XP and Vista and use ZoneAlarm Internet Security Suite 2009 (about $39.95/year online). I believe the AntiVirus part of it is Computer Associates. I never have a problem, and hope to stay that way. I have also been using SUPERAntiSpyware for the past few years with good luck, also.
Just remember to disable System Restore before booting into Safe Mode and scanning for nasties, but you already know that.
Good luck. And thanks for all your help in the past.
TriAngle
Postby evasive » Mon Jul 20, 2009 9:08 pm
Uwhen I encounter an AntiVirus2009 infection I backup and do a full reinstall, reason being this POS constantly changes and puts new cr*p everywhere in windows. It is virtually impossible to restore 100% because it also opens your system to other baddies...
Postby Toby B. » Fri Aug 21, 2009 8:26 am
Im about two milliseconds from saying to HELL with windblows..... I get home from work today and am watching a movie on the PC (DL from blockbuster), and this ______________ $*%^$ starts again. Windows Antivirus Pro.
CA is setup just as AVG was (to auto update and scan.).. Now CA is disabled and Malwarebytes wot start either.....
This is pissing me off, simply cause I dont have the $200+ to get another OS disk... :mb_angry::
Toby B.
Postby Toby B. » Fri Aug 21, 2009 12:06 pm
Ok I went into safemode and was able to run Malwarebytes (found 60 infections). I then rebooted into normal mode and Spybot Started right off the bat... I saved the report of what it found. I did select clean all but by looking at the report, it may or may nor have cleaned it...
--- Search result list ---
Microsoft.Windows.ActiveDesktop: [SBI $99FAD8A8] User settings (Registry change, nothing done)
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Policies\ActiveDesktop\NoChangingWallpaper
HKEY_USERS\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Policies\ActiveDesktop\NoChangingWallpaper
Microsoft.Windows.Explorer: [SBI $1931FF4D] Settings (Registry change, nothing done)
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoActiveDesktopChanges
HKEY_USERS\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoActiveDesktopChanges
Microsoft.WindowsSecurityCenter_disabled: [SBI $2E20C9A9] Settings (Registry change, nothing done)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wscsvc\Start
Virtumonde: [SBI $92386332] Library (File, nothing done)
C:\WINDOWS\system32\unicows.dll
Virtumonde.Dll: [SBI $92386332] Library (File, nothing done)
C:\WINDOWS\system32\zipfldr.dll
Win32.TDSS.rtk: [SBI $52718CC2] File (File, nothing done)
C:\WINDOWS\system32\drivers\hjgruinscurtbe.sys
Win32.TDSS.rtk: [SBI $FD7B715A] File (File, nothing done)
C:\WINDOWS\system32\hjgruighqewhbw.dll
C:\WINDOWS\system32\hjgruikuppnsch.dll
Win32.TDSS.rtk: [SBI $2A4B8272] File (File, nothing done)
C:\WINDOWS\temp\hjgruierxmbcopcy.tmp
Win32.TDSS.rtk: [SBI $6361226C] File (File, nothing done)
C:\WINDOWS\system32\hjgruincpbjumw.dat
C:\WINDOWS\system32\hjgruiovubxmhx.dat
Win32.TDSS.rtk: [SBI $83AE5231] File (File, nothing done)
C:\WINDOWS\system32\UACpvfhfusagorodoicu.dat
Statcounter: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
MediaPlex: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
DoubleClick: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
FastClick: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
Right Media: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
Zedo: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
CasaleMedia: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
Clickbank: Tracking cookie (Internet Explorer: Toby Bibeau) (Cookie, nothing done)
--- Spybot - Search & Destroy version: 1.5.2 (build: 20080128) ---
2008-01-28 blindman.exe (1.0.0.7)
2008-01-28 SDDelFile.exe (1.0.2.4)
2008-01-28 SDMain.exe (1.0.0.5)
2007-10-07 SDShred.exe (1.0.1.2)
2008-01-28 SDUpdate.exe (1.0.8.8)
2008-01-28 SDWinSec.exe (1.0.0.11)
2008-01-28 SpybotSD.exe (1.5.2.20)
2009-03-05 TeaTimer.exe (1.6.6.32)
2009-08-13 unins000.exe (51.49.0.0)
2008-01-28 Update.exe (1.4.0.6)
2009-07-28 advcheck.dll (1.6.3.17)
2007-04-02 aports.dll (2.1.0.0)
2007-11-17 DelZip179.dll (1.79.7.4)
2008-01-28 SDFiles.dll (1.5.1.19)
2008-09-15 SDHelper.dll (1.6.2.14)
2008-10-22 Tools.dll (2.1.6.8)
2009-05-19 Includes\Adware.sbi (*)
2009-07-30 Includes\AdwareC.sbi (*)
2009-01-22 Includes\Cookies.sbi (*)
2009-05-19 Includes\Dialer.sbi (*)
2009-08-04 Includes\DialerC.sbi (*)
2009-01-22 Includes\HeavyDuty.sbi (*)
2009-05-26 Includes\Hijackers.sbi (*)
2009-08-04 Includes\HijackersC.sbi (*)
2009-06-23 Includes\Keyloggers.sbi (*)
2009-07-30 Includes\KeyloggersC.sbi (*)
2004-11-29 Includes\LSP.sbi (*)
2009-08-11 Includes\Malware.sbi (*)
2009-08-11 Includes\MalwareC.sbi (*)
2009-03-25 Includes\PUPS.sbi (*)
2009-08-06 Includes\PUPSC.sbi (*)
2009-01-22 Includes\Revision.sbi (*)
2009-01-13 Includes\Security.sbi (*)
2009-07-30 Includes\SecurityC.sbi (*)
2008-06-03 Includes\Spybots.sbi (*)
2008-06-03 Includes\SpybotsC.sbi (*)
2009-04-07 Includes\Spyware.sbi (*)
2009-08-11 Includes\SpywareC.sbi (*)
2009-06-08 Includes\Tracks.uti
2009-08-11 Includes\Trojans.sbi (*)
2009-08-12 Includes\TrojansC.sbi (*)
2008-03-04 Plugins\Chai.dll
2008-03-05 Plugins\Fennel.dll
2008-02-26 Plugins\Mate.dll
2007-12-24 Plugins\TCPIPAddress.dll
--- System information ---
Windows XP (Build: 2600) Service Pack 3 (5.1.2600)
/ Windows / SP1: Microsoft Internationalized Domain Names Mitigation APIs
/ Windows / SP1: Microsoft National Language Support Downlevel APIs
/ Windows Media Format 11 SDK: Hotfix for Windows Media Format 11 SDK (KB929399)
/ Windows Media Player: Security Update for Windows Media Player (KB952069)
/ Windows Media Player: Security Update for Windows Media Player (KB973540)
/ Windows Media Player 11: Security Update for Windows Media Player 11 (KB936782)
/ Windows Media Player 11: Hotfix for Windows Media Player 11 (KB939683)
/ Windows Media Player 11: Security Update for Windows Media Player 11 (KB954154)
/ Windows Media Player 11: Critical Update for Windows Media Player 11 (KB959772)
/ Windows Media Player 6.4: Security Update for Windows Media Player 6.4 (KB925398)
/ Windows Media Player 9: Security Update for Windows Media Player 9 (KB917734)
/ Windows Media Player 9: Security Update for Windows Media Player 9 (KB936782)
/ Windows XP: Security Update for Windows XP (KB923689)
/ Windows XP: Security Update for Windows XP (KB941569)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB937143)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB938127)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB939653)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB942615)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB944533)
/ Windows XP / SP0: Hotfix for Windows Internet Explorer 7 (KB947864)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB950759)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB958215)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB960714)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB961260)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB969897)
/ Windows XP / SP0: Security Update for Windows Internet Explorer 7 (KB972260)
/ Windows XP / SP10: Microsoft Compression Client Pack 1.0 for Windows XP
/ Windows XP / SP3: Windows XP Service Pack 3
/ Windows XP / SP4: Security Update for Windows XP (KB923561)
/ Windows XP / SP4: Security Update for Windows XP (KB938464)
/ Windows XP / SP4: Security Update for Windows XP (KB938464-v2)
/ Windows XP / SP4: Security Update for Windows XP (KB946648)
/ Windows XP / SP4: Security Update for Windows XP (KB950760)
/ Windows XP / SP4: Security Update for Windows XP (KB950762)
/ Windows XP / SP4: Security Update for Windows XP (KB950974)
/ Windows XP / SP4: Security Update for Windows XP (KB951066)
/ Windows XP / SP4: Security Update for Windows XP (KB951376-v2)
/ Windows XP / SP4: Security Update for Windows XP (KB951698)
/ Windows XP / SP4: Security Update for Windows XP (KB951748)
/ Windows XP / SP4: Update for Windows XP (KB951978)
/ Windows XP / SP4: Security Update for Windows XP (KB952004)
/ Windows XP / SP4: Hotfix for Windows XP (KB952287)
/ Windows XP / SP4: Security Update for Windows XP (KB952954)
/ Windows XP / SP4: Security Update for Windows XP (KB954211)
/ Windows XP / SP4: Security Update for Windows XP (KB954459)
/ Windows XP / SP4: Hotfix for Windows XP (KB954550-v5)
/ Windows XP / SP4: Security Update for Windows XP (KB954600)
/ Windows XP / SP4: Security Update for Windows XP (KB955069)
/ Windows XP / SP4: Update for Windows XP (KB955839)
/ Windows XP / SP4: Security Update for Windows XP (KB956391)
/ Windows XP / SP4: Security Update for Windows XP (KB956572)
/ Windows XP / SP4: Security Update for Windows XP (KB956744)
/ Windows XP / SP4: Security Update for Windows XP (KB956802)
/ Windows XP / SP4: Security Update for Windows XP (KB956803)
/ Windows XP / SP4: Security Update for Windows XP (KB956841)
/ Windows XP / SP4: Security Update for Windows XP (KB957095)
/ Windows XP / SP4: Security Update for Windows XP (KB957097)
/ Windows XP / SP4: Security Update for Windows XP (KB958644)
/ Windows XP / SP4: Security Update for Windows XP (KB958687)
/ Windows XP / SP4: Security Update for Windows XP (KB959426)
/ Windows XP / SP4: Security Update for Windows XP (KB960225)
/ Windows XP / SP4: Security Update for Windows XP (KB960715)
/ Windows XP / SP4: Security Update for Windows XP (KB960803)
/ Windows XP / SP4: Security Update for Windows XP (KB960859)
/ Windows XP / SP4: Hotfix for Windows XP (KB961118)
/ Windows XP / SP4: Security Update for Windows XP (KB961371)
/ Windows XP / SP4: Security Update for Windows XP (KB961373)
/ Windows XP / SP4: Security Update for Windows XP (KB961501)
/ Windows XP / SP4: Update for Windows XP (KB967715)
/ Windows XP / SP4: Update for Windows XP (KB968389)
/ Windows XP / SP4: Security Update for Windows XP (KB968537)
/ Windows XP / SP4: Security Update for Windows XP (KB969898)
/ Windows XP / SP4: Security Update for Windows XP (KB970238)
/ Windows XP / SP4: Security Update for Windows XP (KB971557)
/ Windows XP / SP4: Security Update for Windows XP (KB971633)
/ Windows XP / SP4: Security Update for Windows XP (KB971657)
/ Windows XP / SP4: Security Update for Windows XP (KB973346)
/ Windows XP / SP4: Security Update for Windows XP (KB973354)
/ Windows XP / SP4: Security Update for Windows XP (KB973507)
/ Windows XP / SP4: Update for Windows XP (KB973815)
/ Windows XP / SP4: Security Update for Windows XP (KB973869)
--- Startup entries list ---
Located: HK_LM:Run, Adobe Photo Downloader
command: "C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe"
file: C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe
MD5: 617FA5BE646B5E8D6670FD4710ACD2D3
Located: HK_LM:Run, Adobe Reader Speed Launcher
command: "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
file: C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe
MD5: 8B9145D229D4E89D15ACB820D4A3A90F
Located: HK_LM:Run, BrMfcWnd
command: C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN
file: C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe
MD5: 7E17313EE7DF61660FC95A633268DC74
Located: HK_LM:Run, CAVRID
command: "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe"
file: C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe
MD5: AB50997744751CC8FCDFE700D6AC7F15
Located: HK_LM:Run, cctray
command: "C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe"
file: C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe
MD5: 76AC1FBBB28054EDFA6ABB85E24B32EB
Located: HK_LM:Run, ControlCenter3
command: C:\Program Files\Brother\ControlCenter3\brctrcen.exe /autorun
file: C:\Program Files\Brother\ControlCenter3\brctrcen.exe
MD5: 953372CBBC6404B0C0636D06B1C74B9B
Located: HK_LM:Run, LoadMSvcmm
command: "C:\Program Files\Blockbuster\BLOCKBUSTERMovielink\Movielink User.exe"
file: C:\Program Files\Blockbuster\BLOCKBUSTERMovielink\Movielink User.exe
MD5: 67AA484BAD4B6A6005D87554841C2D43
Located: HK_LM:Run, NvCplDaemon
command: RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
file:
MD5: D41D8CD98F00B204E9800998ECF8427E
Warning: if the file is actually larger than 0 bytes,
the checksum could not be properly calculated!
Located: HK_LM:Run, SetDefPrt
command: C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe
file: C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe
MD5: 0C6DC7F88DF16A6851BD11A48A03DA1B
Located: HK_LM:Run, SoundMan
command: SOUNDMAN.EXE
file: C:\WINDOWS\SOUNDMAN.EXE
MD5: FB1BC9A15A3DF6CFD446E1B3BD0B5099
Located: HK_LM:Run, SunJavaUpdateSched
command: "C:\Program Files\Java\jre6\bin\jusched.exe"
file: C:\Program Files\Java\jre6\bin\jusched.exe
MD5: D22D936F9AB0DA3B8EB7537284867708
Located: HK_LM:RunOnce, Malwarebytes Anti-Malware (reboot)
command: "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
file: C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
MD5: F4338500B2616B89B2FBF2295AA09377
Located: HK_LM:RunOnce, Spybot - Search & Destroy
command: "C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe" /autocheck
file: C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
MD5: 2ECA8CDEED7C82F879E766DA92A3561A
Located: HK_CU:Run, ctfmon.exe
where: PE_C_ADMINISTRATOR...
command: C:\WINDOWS\system32\ctfmon.exe
file: C:\WINDOWS\system32\ctfmon.exe
MD5: 5F1D5F88303D4A4DBC8E5F97BA967CC3
where: S-1-5-21-1409082233-1123561945-725345543-1003...
Located: HK_CU:Run, SpybotSD TeaTimer
command: C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
file: C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
MD5: 390679F7A217A5E73D756276C40AE887
Located: Startup (disabled), ymetray (DISABLED)
command: C:\PROGRA~1\Yahoo!\YAHOO!~1\ymetray.exe C:\Program Files\Yahoo!\Yahoo! Music Jukebox\YahooMusicEngine.exe -preload
file:
Located: Startup (disabled), LimeWire On Startup (DISABLED)
command: C:\PROGRA~1\LimeWire\LimeWire.exe -startup
file:
Located: WinLogon, AtiExtEvent
command: Ati2evxx.dll
file: Ati2evxx.dll
Located: WinLogon, crypt32chain
command: crypt32.dll
file: crypt32.dll
Located: WinLogon, cryptnet
command: cryptnet.dll
file: cryptnet.dll
Located: WinLogon, cscdll
command: cscdll.dll
file: cscdll.dll
Located: WinLogon, ScCertProp
command: wlnotify.dll
file: wlnotify.dll
Located: WinLogon, Schedule
file: wlnotify.dll
Located: WinLogon, sclgntfy
command: sclgntfy.dll
file: sclgntfy.dll
Located: WinLogon, SensLogn
command: WlNotify.dll
file: WlNotify.dll
Located: WinLogon, termsrv
file: wlnotify.dll
Located: WinLogon, wlballoon
file: wlnotify.dll
--- Browser helper object list ---
{201f27d4-3704-41d6-89c1-aa35e39143ed} ()
location: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\
BHO name:
CLSID name:
{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} (WormRadar.com IESiteBlocker.NavFilter)
BHO name: WormRadar.com IESiteBlocker.NavFilter
CLSID name:
{A3BC75A2-1F87-4686-AA43-5347D756017C} ()
BHO name:
CLSID name:
{DBC80044-A445-435b-BC74-9C25C1C588A9} (Java(tm) Plug-In 2 SSV Helper)
BHO name:
CLSID name: Java(tm) Plug-In 2 SSV Helper
Path: C:\Program Files\Java\jre6\bin\
Long name: jp2ssv.dll
Short name:
Date (created): 7/9/2009 4:35:36 PM
Date (last access): 8/21/2009 1:51:36 PM
Date (last write): 7/9/2009 4:35:36 PM
Filesize: 41368
Attributes: archive
MD5: 192E39C717013A0BD532B33AC29D6E7D
CRC32: 6D4D2A2E
Version: 6.0.140.8
{E7E6F031-17CE-4C07-BC86-EABFE594F69C} (JQSIEStartDetectorImpl)
BHO name: JQSIEStartDetectorImpl
CLSID name: JQSIEStartDetectorImpl Class
Path: C:\Program Files\Java\jre6\lib\deploy\jqs\ie\
Long name: jqs_plugin.dll
Short name: JQS_PL~1.DLL
Date (created): 7/9/2009 4:35:38 PM
Date (last write): 7/9/2009 4:35:38 PM
Filesize: 73728
Attributes: archive
MD5: 9A0CA264EC3210E77764C45AD7C5F339
CRC32: A8965ADA
Version: 6.0.140.8
{F0F61477-5546-4E96-8A14-0C2FC134DAC2} ()
BHO name:
CLSID name:
{FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} (SingleInstance Class)
BHO name:
CLSID name: SingleInstance Class
Path: C:\Program Files\Yahoo!\Companion\Installs\cpn0\
Long name: YTSingleInstance.dll
Short name: YTSING~1.DLL
Date (created): 11/20/2008 5:21:28 PM
Date (last access): 8/21/2009 3:39:40 PM
Date (last write): 11/20/2008 5:21:28 PM
Filesize: 160496
Attributes: archive
MD5: E68542BC9F4771C269D7CA6DC1210524
CRC32: 5317FDF2
Version: 2008.11.20.1
--- ActiveX list ---
{17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool)
DPF name:
CLSID name: Windows Genuine Advantage Validation Tool
Installer: C:\WINDOWS\Downloaded Program Files\LegitCheckControl.inf
Codebase: http://download.microsoft.com/download/ ... ontrol.cab
description:
classification: Legitimate
known filename: LegitCheckControl.DLL
info link:
info source: Safer Networking Ltd.
Path: C:\WINDOWS\system32\
Long name: LegitCheckControl.dll
Short name: LEGITC~1.DLL
Date (created): 3/15/2007 6:19:28 PM
Date (last access): 8/21/2009 12:59:12 PM
Date (last write): 9/6/2008 12:30:06 AM
Filesize: 1480232
Attributes: archive
MD5: D0E44C9C8BD85350828458EAD715BD30
CRC32: 1F5F2366
Version: 1.8.31.9
{2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner)
DPF name:
CLSID name: Symantec AntiVirus scanner
Installer: C:\WINDOWS\Downloaded Program Files\avsniff.inf
Codebase: http://security.symantec.com/sscv6/Shar ... vSniff.cab
description: Symantec online scanner
known filename: AVSNIFF.DLL
info link:
info source: Patrick M. Kolla
Path: C:\WINDOWS\Downloaded Program Files\
Long name: avsniff.dll
Short name:
Date (created): 6/12/2009 1:05:06 PM
Date (last access): 8/21/2009 12:54:20 PM
Date (last write): 6/12/2009 1:05:06 PM
Filesize: 312680
Attributes: archive
MD5: 6E3E681770908A8A8B1662B854C31A36
CRC32: D7C0125C
Version: 2006.2.22.58
{30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class)
DPF name:
CLSID name: YInstStarter Class
Installer: C:\Program Files\Yahoo!\Common\yinst.inf
Codebase: C:\Program Files\Yahoo!\Common\yinsthelper.dll
description: Yahoo! Installation helper
known filename: %SystemRoot%\Downloaded Program Files\yinsthelper.dll
info link:
Path: C:\PROGRA~1\Yahoo!\Common\
Long name: yinsthelper.dll
Short name: YINSTH~1.DLL
Date (created): 10/17/2007 1:00:46 PM
Date (last access): 8/21/2009 12:50:20 PM
Date (last write): 7/30/2006 1:25:34 PM
Filesize: 188968
Attributes: archive
MD5: 18B54B53CEE0E7204495BAB864EBBF03
CRC32: 6D72BB93
Version: 2006.4.14.2
{4871A87A-BFDD-4106-8153-FFDE2BAC2967} (DLM Control)
DPF name:
CLSID name: DLM Control
Installer: C:\WINDOWS\Downloaded Program Files\DownloadManagerV2.inf
Codebase: http://dlm.tools.akamai.com/dlmanager/v ... .2.4.3.cab
Path: C:\WINDOWS\DOWNLO~1\
Long name: DownloadManagerV2.ocx
Short name: DOWNLO~1.OCX
Date (created): 7/23/2008 8:25:52 AM
Date (last write): 7/23/2008 8:25:52 AM
Filesize: 45056
Attributes: archive
MD5: B715701E20988CDAC038093F92C3C2FF
CRC32: BB8C3F6D
Version: 2.2.4.3
{644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class)
DPF name:
CLSID name: Symantec RuFSI Utility Class
Installer: C:\WINDOWS\Downloaded Program Files\CabSA.inf
Codebase: http://security.symantec.com/sscv6/Shar ... /cabsa.cab
description:
known filename: rufsi.dll
info link:
Long name: rufsi.dll
Short name:
Date (created): 6/12/2009 1:05:16 PM
Date (last write): 6/12/2009 1:05:16 PM
Filesize: 296336
Attributes: archive
MD5: A5D2808487F72F9A8C08B24AE2E0D203
CRC32: 1DAC0E6B
Version: 2006.2.15.43
{67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object)
DPF name:
CLSID name: DivXBrowserPlugin Object
Installer: C:\WINDOWS\Downloaded Program Files\DivXPlugin.inf
Codebase: http://go.divx.com/plugin/DivXBrowserPlugin.cab
description:
known filename: npdivx32.dll
info link:
Path: C:\Program Files\DivX\DivX Web Player\
Long name: npdivx32.dll
Short name:
Date (created): 4/22/2007 8:02:20 PM
Date (last access): 8/21/2009 12:47:46 PM
Date (last write): 2/20/2008 10:04:00 PM
Filesize: 1335600
Attributes: archive
MD5: 56E18C09654020009012A53FD332D397
CRC32: 56B7CC16
Version: 1.4.0.233
{6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class)
DPF name:
CLSID name: MUWebControl Class
Installer: C:\WINDOWS\Downloaded Program Files\muweb.inf
Codebase: http://www.update.microsoft.com/microso ... 0680954281
description:
known filename: muweb.dll
info link:
Long name: muweb.dll
Short name:
Date (created): 7/30/2007 7:18:34 PM
Date (last access): 8/21/2009 3:39:42 PM
Date (last write): 10/16/2008 3:06:48 PM
Filesize: 208744
Attributes: archive
MD5: D2E6F0A06391FE5556E8A1D6D5041A5E
CRC32: 27FBFA7D
Version: 7.2.6001.788
{8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0)
DPF name: Java Runtime Environment 1.6.0
CLSID name: Java Plug-in 1.6.0_14
Installer:
Codebase: http://java.sun.com/update/1.6.0/jinsta ... s-i586.cab
description: Sun Java
known filename: %PROGRAM FILES%\JabaSoft\JRE\*\Bin\npjava131.dll
info link:
Long name: npjpi160_14.dll
Short name: NPJPI1~1.DLL
Date (last access): 8/21/2009 12:48:22 PM
Filesize: 136600
Attributes: archive
MD5: 104191689E114BEF5C92A6BD626FA4F3
CRC32: 9D46C674
Version: 6.0.140.8
{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA} (Java Runtime Environment 1.5.0)
DPF name: Java Runtime Environment 1.5.0
CLSID name: Java Plug-in 1.5.0_03
Installer:
Codebase: http://java.sun.com/update/1.5.0/jinsta ... s-i586.cab
description:
known filename: NPJPI150_03.dll
info link:
Path: C:\Program Files\Java\jre1.5.0_03\bin\
Long name: NPJPI150_03.dll
Date (created): 4/13/2005 3:48:56 AM
Date (last access): 8/21/2009 12:47:54 PM
Date (last write): 4/13/2005 4:06:32 AM
Filesize: 69746
Attributes:
MD5: 13FCA03EBCA6E1F8C6481166C516D1FE
CRC32: 868C298F
Version: 5.0.30.7
{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
CLSID name: Java Plug-in 1.6.0_01
Installer:
description:
known filename: npjpi160_01.dll
info link:
Path: C:\Program Files\Java\jre1.6.0_01\bin\
Long name: npjpi160_01.dll
Date (created): 3/14/2007 2:04:46 AM
Date (last access): 8/21/2009 12:47:58 PM
Date (last write): 3/14/2007 3:43:42 AM
Filesize: 132760
Attributes: archive
MD5: F112FB2FD2EF66D439799E3F834DF000
CRC32: D2B09219
Version: 6.0.0.6
{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
CLSID name: Java Plug-in 1.6.0_02
Installer:
description:
known filename: npjpi160_02.dll
info link:
Path: C:\Program Files\Java\jre1.6.0_02\bin\
Long name: npjpi160_02.dll
Date (created): 7/12/2007 2:22:38 AM
Date (last access): 8/21/2009 12:48:02 PM
Date (last write): 7/12/2007 4:00:36 AM
Filesize: 132496
Attributes: archive
MD5: E3811F1A1C5063C941EC0E2766C3EA39
CRC32: AEFD3747
Version: 6.0.20.6
{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
CLSID name: Java Plug-in 1.6.0_03
Installer:
Path: C:\Program Files\Java\jre1.6.0_03\bin\
Long name: npjpi160_03.dll
Date (created): 9/24/2007 11:31:44 PM
Date (last access): 8/21/2009 12:48:06 PM
Date (last write): 9/25/2007 1:11:34 AM
Filesize: 132496
Attributes: archive
MD5: D6A4682A6FF41832A3F1A7AB9AE08199
CRC32: 9080B537
Version: 6.0.30.5
{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
CLSID name: Java Plug-in 1.6.0_05
Installer:
Path: C:\Program Files\Java\jre1.6.0_05\bin\
Long name: npjpi160_05.dll
Date (created): 2/22/2008 2:33:32 AM
Date (last access): 8/21/2009 12:48:12 PM
Date (last write): 2/22/2008 4:25:20 AM
Filesize: 132496
Attributes: archive
MD5: 4FDFB86D78994BD71CBB779A7809E9CD
CRC32: 5A0EB880
Version: 6.0.50.13
{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
CLSID name: Java Plug-in 1.6.0_07
Installer:
Path: C:\Program Files\Java\jre1.6.0_07\bin\
Long name: npjpi160_07.dll
Date (created): 6/10/2008 2:32:34 AM
Date (last access): 8/21/2009 12:48:16 PM
Date (last write): 6/10/2008 4:27:02 AM
Filesize: 132496
Attributes: archive
MD5: 7C83A2809E13950359189767AC9D5DB8
CRC32: 925C2A88
Version: 6.0.70.6
{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
Installer:
Date (last access): 8/21/2009 3:41:54 PM
Filesize: 136600
Attributes: archive
CRC32: 9D46C674
Version: 6.0.140.8
{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} (Java Runtime Environment 1.6.0)
Installer:
description:
known filename: npjpi150_06.dll
info link:
Filesize: 136600
Attributes: archive
CRC32: 9D46C674
Version: 6.0.140.8
{D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object)
DPF name:
CLSID name: Shockwave Flash Object
Installer: C:\WINDOWS\Downloaded Program Files\swflash.inf
Codebase: http://fpdownload2.macromedia.com/get/s ... wflash.cab
description: Macromedia Shockwave Flash Player
known filename:
info link:
Path: C:\WINDOWS\system32\Macromed\Flash\
Long name: Flash10c.ocx
Short name:
Date (created): 7/17/2009 11:12:12 PM
Date (last access): 8/21/2009 12:30:28 PM
Date (last write): 7/17/2009 11:12:12 PM
Filesize: 3979680
Attributes: readonly archive
MD5: 43C6ACDFB92A18C3E516E6BD5F1ACD51
CRC32: D6F40D46
Version: 10.0.32.18
--- Process list ---
PID: 0 ( 0) [System]
PID: 416 ( 4) \SystemRoot\System32\smss.exe
PID: 552 ( 416) \??\C:\WINDOWS\system32\csrss.exe
PID: 648 ( 416) \??\C:\WINDOWS\system32\winlogon.exe
PID: 744 ( 648) C:\WINDOWS\system32\services.exe
MD5: 65DF52F5B8B6E9BBD183505225C37315
PID: 756 ( 648) C:\WINDOWS\system32\lsass.exe
MD5: BF2466B3E18E970D8A976FB95FC1CA85
PID: 968 ( 744) C:\WINDOWS\system32\Ati2evxx.exe
MD5: B8DBF155EAE86B1468FEEA472E94AEFB
PID: 1032 ( 744) C:\WINDOWS\system32\svchost.exe
MD5: 27C6D03BCDB8CFEB96B716F3D8BE3E18
PID: 1140 ( 744) C:\WINDOWS\system32\svchost.exe
PID: 1228 ( 744) C:\WINDOWS\System32\svchost.exe
PID: 1296 ( 744) C:\WINDOWS\system32\svchost.exe
PID: 1344 ( 648) C:\WINDOWS\system32\Ati2evxx.exe
PID: 1480 ( 744) C:\WINDOWS\system32\svchost.exe
PID: 1596 ( 744) C:\WINDOWS\system32\spoolsv.exe
MD5: D8E14A61ACC1D4A6CD0D38AEBAC7FA3B
PID: 1716 ( 744) C:\WINDOWS\system32\svchost.exe
PID: 1776 ( 744) C:\Program Files\Common Files\Seagate\Schedule2\schedul2.exe
MD5: C0C8248730EBB49BD8DF2B0981FCA312
PID: 1812 ( 744) C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
MD5: 58DA9AB565E54A3A7C1FB53CEB075F49
PID: 1928 ( 744) C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
MD5: 5E849A81827D643E7E35575E14225E92
PID: 192 ( 744) C:\Program Files\Java\jre6\bin\jqs.exe
MD5: 44FFBA62F0F426B581759C49AAFEC2E2
PID: 456 ( 744) C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
MD5: 11F714F85530A2BD134074DC30E99FCA
PID: 480 ( 404) C:\WINDOWS\Explorer.EXE
MD5: 12896823FB95BFB3DC9B46BCAEDC9923
PID: 508 ( 744) C:\PROGRA~1\BLOCKB~1\BLOCKB~1\MovielinkCore.exe
MD5: F8DA514BA3DDD6470C4D018B5AD31789
PID: 664 ( 480) C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
PID: 1200 ( 744) C:\WINDOWS\system32\svchost.exe
PID: 1396 ( 744) C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
MD5: C2FDBA6CFD5762EAA6D20E7E235CF4E0
PID: 1608 ( 744) C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
MD5: DD0042F0C3B606A6A8B92D49AFB18AD6
PID: 304 ( 744) C:\WINDOWS\System32\alg.exe
MD5: 8C515081584A38AA007909CD02020B3D
PID: 4 ( 0) System
--- Browser start & search pages list ---
Spybot - Search & Destroy browser pages report, 8/21/2009 3:41:54 PM
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Local Page
C:\WINDOWS\system32\blank.htm
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Search Page
http://www.microsoft.com/isapi/redir.dl ... r=iesearch
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Start Page
about:blank
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Local Page
%SystemRoot%\system32\blank.htm
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main\Start Page
about:blank
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Search\SearchAssistant
http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchasst.htm
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Search\CustomizeSearch
http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchcust.htm
--- Winsock Layered Service Provider list ---
Protocol 0: CA ISafe LSP over [MSAFD Tcpip [TCP/IP]]
GUID: {F97F3228-3A03-4D83-AD9C-D86AEF099196}
Filename: C:\WINDOWS\system32\VetRedir.dll
Protocol 1: CA ISafe LSP over [MSAFD Tcpip [UDP/IP]]
Protocol 2: CA ISafe LSP over [MSAFD Tcpip [RAW/IP]]
Protocol 28: CA ISafe LSP
GUID: {AE2578B4-F478-4313-9A3E-1B83F7A643DF}
--- Uninstall list ---
(AddressBook)
Adobe Flash Player 10 ActiveX 10.0.32.18 (Adobe Flash Player ActiveX)
uninstall cmd: C:\WINDOWS\system32\Macromed\Flash\uninstall_activeX.exe
publisher: Adobe Systems Incorporated
help link: http://www.adobe.com/go/flashplayer_support/
ATI - Software Uninstall Utility 6.14.10.1022 (All ATI Software)
install location: C:\Program Files\ATI Technologies\UninstallAll
uninstall cmd: C:\Program Files\ATI Technologies\UninstallAll\AtiCimUn.exe
ATI Display Driver 8.573-090113a-074230C-ATI (ATI Display Driver)
uninstall cmd: rundll32 C:\WINDOWS\system32\atiiiexx.dll,_InfEngUnInstallINFFile_RunDLL@16 -force_restart -flags:0x2010001 -inf_class:DISPLAY -clean
(Branding)
CCleaner (remove only) (CCleaner)
uninstall cmd: "C:\Program Files\CCleaner\uninst.exe"
publisher: Piriform
(Connection Manager)
Crimson Editor (remove only) (Crimson Editor)
uninstall cmd: C:\Program Files\Crimson Editor\uninstall.exe
(DirectAnimation)
(DirectDrawEx)
DVD Shrink 3.2 (DVD Shrink_is1)
install location: C:\Program Files\DVD Shrink\
uninstall cmd: "C:\Program Files\DVD Shrink\unins000.exe"
publisher: DVD Shrink
help link: http://www.dvdshrink.org
(DXM_Runtime)
CA Internet Security Suite 4.0.0.205 (eTrust Suite Personal)
install location: C:\Program Files\CA\CA Internet Security Suite
uninstall cmd: "C:\Program Files\CA\CA Internet Security Suite\caunst.exe" /u
publisher: CA, Inc.
help link: http://www.my-etrust.com/Redirect/router.aspx?OEM= &prod=SL&app=inclient&lang=en&date=1247255963&link_id=1&dest=main_support&lic=4Y4TKECWXGCYIEXRWMIC&ver=4.0.0.115
(Fontcore)
FTP Commander (FTP Commander)
uninstall cmd: C:\Program Files\FTP Commander\uninstall.exe
HighPoint ATA RAID Management Software (HighPoint ATA RAID Management Software)
uninstall cmd: C:\WINDOWS\IsUninst.exe -f"C:\Program Files\HighPoint Technologies, Inc\HighPoint ATA RAID Management Software\Uninst.isu"
HijackThis 1.99.1 1.99.1 (HijackThis)
uninstall cmd: C:\hjt\HijackThis.exe /uninstall
publisher: Soeperman Enterprises Ltd.
(ICW)
Microsoft Internationalized Domain Names Mitigation APIs (IDNMitigationAPIs)
install date: 20070925
uninstall cmd: "C:\WINDOWS\$NtServicePackUninstallIDNMitigationAPIs$\spuninst\spuninst.exe"
publisher: Microsoft Corporation
(IE40)
(IE4Data)
(IE5BAKEX)
Windows Internet Explorer 7 20061107.210142 (ie7)
help link: http://www.microsoft.com/ie
(IEData)
(InstallShield Uninstall Information)
(KB884016)
(KB884267)
(KB885353)
(KB886612)
(KB887078)
(KB887626)
(KB888656)
(KB889858)
(KB891122)
(KB892313)
(KB893240)
(KB893241)
(KB893803)
(KB895181)
(KB895316)
(KB895572)
(KB897586)
(KB898549)
(KB900399)
(KB902344)
(KB907658)
(KB911565)
(KB911854)
Security Update for Windows XP (KB923789) (KB923789)
uninstall cmd: C:\WINDOWS\system32\MacroMed\Flash\genuinst.exe C:\WINDOWS\system32\MacroMed\Flash\KB923789.inf
help link: http://support.microsoft.com?kbid=923789
Security Update for Windows Internet Explorer 7 (KB937143) 1 (KB937143-IE7)
uninstall cmd: "C:\WINDOWS\ie7updates\KB937143-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=937143
Security Update for Windows Internet Explorer 7 (KB938127) 1 (KB938127-IE7)
uninstall cmd: "C:\WINDOWS\ie7updates\KB938127-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=938127
Security Update for Windows Internet Explorer 7 (KB939653) 1 (KB939653-IE7)
install date: 20071011
uninstall cmd: "C:\WINDOWS\ie7updates\KB939653-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=939653
(KB941569)
Security Update for Windows Internet Explorer 7 (KB942615) 1 (KB942615-IE7)
install date: 20071212
uninstall cmd: "C:\WINDOWS\ie7updates\KB942615-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=942615
Security Update for Windows Internet Explorer 7 (KB944533) 1 (KB944533-IE7)
install date: 20080213
uninstall cmd: "C:\WINDOWS\ie7updates\KB944533-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=944533
(KB946648)
Hotfix for Windows Internet Explorer 7 (KB947864) 1 (KB947864-IE7)
install date: 20080503
uninstall cmd: "C:\WINDOWS\ie7updates\KB947864-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=947864
Security Update for Windows Internet Explorer 7 (KB950759) 1 (KB950759-IE7)
install date: 20080812
uninstall cmd: "C:\WINDOWS\ie7updates\KB950759-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=950759
(KB950762)
(KB950974)
(KB951066)
(KB951376-v2)
(KB951698)
(KB951748)
(KB952287)
(KB952954)
Hotfix for Windows XP (KB954550-v5) 5 (KB954550-v5)
install date: 20081124
help link: http://support.microsoft.com?kbid=954550
(KB957095)
(KB957097)
Security Update for Windows Internet Explorer 7 (KB958215) 1 (KB958215-IE7)
install date: 20090110
uninstall cmd: "C:\WINDOWS\ie7updates\KB958215-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=958215
Security Update for Windows Internet Explorer 7 (KB960714) 1 (KB960714-IE7)
uninstall cmd: "C:\WINDOWS\ie7updates\KB960714-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=960714
Security Update for Windows Internet Explorer 7 (KB961260) 1 (KB961260-IE7)
install date: 20090213
uninstall cmd: "C:\WINDOWS\ie7updates\KB961260-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=961260
Security Update for Windows Internet Explorer 7 (KB969897) 1 (KB969897-IE7)
install date: 20090710
uninstall cmd: "C:\WINDOWS\ie7updates\KB969897-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=969897
Security Update for Windows Internet Explorer 7 (KB972260) 1 (KB972260-IE7)
install date: 20090728
uninstall cmd: "C:\WINDOWS\ie7updates\KB972260-IE7\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=972260
K-Lite Mega Codec Pack 2.01 2.01 (KLiteCodecPack_is1)
install date: 20070508
install location: C:\Program Files\K-Lite Codec Pack\
uninstall cmd: "C:\Program Files\K-Lite Codec Pack\unins000.exe"
Malwarebytes' Anti-Malware (Malwarebytes' Anti-Malware_is1)
install date: 20090809
install location: C:\Program Files\Malwarebytes' Anti-Malware\
uninstall cmd: "C:\Program Files\Malwarebytes' Anti-Malware\unins000.exe"
publisher: Malwarebytes Corporation
help link: http://www.malwarebytes.org
Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1)
install location: C:\WINDOWS\Microsoft.NET\Framework\v3.5\
uninstall cmd: C:\WINDOWS\Microsoft.NET\Framework\v3.5\Microsoft .NET Framework 3.5 SP1\setup.exe
help link: http://go.microsoft.com/fwlink/?LinkId=120337
(MobileOptionPack)
BLOCKBUSTER Movielink (Movielink Manager)
uninstall cmd: C:\Program Files\Blockbuster\BLOCKBUSTERMovielink\Movielink Util.exe /uninstall
publisher: Blockbuster
(MPlayer2)
Microsoft Compression Client Pack 1.0 for Windows XP 1 (MSCompPackV1)
uninstall cmd: "C:\WINDOWS\$NtUninstallMSCompPackV1$\spuninst\spuninst.exe"
help link: http://go.microsoft.com/fwlink/?LinkId=74087
(MSI30-Beta1)
(MSI30-Beta2)
(MSI30-KB884016)
(MSI30-RC1)
(MSI30-RC2)
(MSI30a-KB884016)
(MSI31-Beta)
(MSI31-RC1)
Ahead Nero Burning ROM (Nero - Burning Rom!UninstallKey)
uninstall cmd: C:\Program Files\Ahead\nero\uninstall\UNNERO.exe /UNINSTALL
(NetMeeting)
Microsoft National Language Support Downlevel APIs (NLSDownlevelMapping)
uninstall cmd: "C:\WINDOWS\$NtServicePackUninstallNLSDownlevelMapping$\spuninst\spuninst.exe"
NVIDIA Drivers (NVIDIA Drivers)
uninstall cmd: C:\WINDOWS\system32\nvudisp.exe UninstallGUI
(OutlookExpress)
(PCHealth)
uninstall cmd: rundll32.exe setupapi.dll,InstallHinfSection DefaultUninstall 132 C:\WINDOWS\INF\PCHealth.inf
(SchedulingAgent)
TeamSpeak 2 RC2 2.0.32.60 (Teamspeak 2 RC2_is1)
uninstall cmd: "C:\Program Files\Teamspeak2_RC2\unins000.exe"
publisher: Dominating Bytes Design
help link: http://www.teamspeak.org
CA Anti-Virus 9.0.0.190 (VETWIN32Vp5)
estimated size: 25600
install location: C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus
uninstall cmd: C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\unvet32.exe
publisher: CA, Inc.
VIA Rhine-Family Fast Ethernet Adapter (VN_VUIns_Rhine_VIA)
uninstall cmd: Rundll32.exe vuins32.dll,vuins32Ex $Rhine $VIA
Windows Genuine Advantage Notifications (KB905474) 1.8.0031.9 (WgaNotify)
help link: http://support.microsoft.com?kbid=905474
Windows Imaging Component 3.0.0.0 (WIC)
uninstall cmd: "C:\WINDOWS\$NtUninstallWIC$\spuninst\spuninst.exe"
Windows Media Format 11 runtime (Windows Media Format Runtime)
uninstall cmd: "C:\Program Files\Windows Media Player\wmsetsdk.exe" /UninstallAll
help link: http://go.microsoft.com/fwlink/?LinkId=62768
Windows Media Player 11 (Windows Media Player)
uninstall cmd: "C:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall
Windows XP Service Pack 3 20080414.031525 (Windows XP Service Pack)
uninstall cmd: "C:\WINDOWS\$NtServicePackUninstall$\spuninst\spuninst.exe"
help link: http://support.microsoft.com?kbid=936929
WinRAR archiver (WinRAR archiver)
uninstall cmd: C:\Program Files\WinRAR\uninstall.exe
(WMCSetup)
Windows Media Format 11 runtime (WMFDist11)
uninstall cmd: "C:\WINDOWS\$NtUninstallWMFDist11$\spuninst\spuninst.exe"
help link: http:
Windows Media Player 11 (wmp11)
uninstall cmd: "C:\WINDOWS\$NtUninstallwmp11$\spuninst\spuninst.exe"
help link: http:
World of Warcraft 3.2.0.10314 (World of Warcraft)
install location: C:\Program Files\World of Warcraft\
install source: C:\Program Files\World of Warcraft\
uninstall cmd: C:\Program Files\Common Files\Blizzard Entertainment\World of Warcraft (2)\Uninstall.exe
publisher: Blizzard Entertainment
Microsoft User-Mode Driver Framework Feature Pack 1.0 (Wudf01000)
uninstall cmd: "C:\WINDOWS\$NtUninstallWudf01000$\spuninst\spuninst.exe"
comments: Build Number 5716
Yahoo! Toolbar (Yahoo! Companion)
uninstall cmd: C:\PROGRA~1\Yahoo!\Common\UNYT_W~1.EXE
Yahoo! Software Update (Yahoo! Software Update)
uninstall cmd: C:\PROGRA~1\Yahoo!\SOFTWA~1\UNINST~1.EXE
(Yahoo! Toolbar)
Yahoo! Install Manager (YInstHelper)
uninstall cmd: C:\WINDOWS\system32\regsvr32 /u C:\PROGRA~1\Yahoo!\Common\YINSTH~1.DLL
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148 9.0.30729.4148 ({002D9D5E-29BA-3E6D-9BC4-3D7D6DBC735C})
version: 151025673
version (major): 9
estimated size: 149
install source: i:\59c65a2b9164aa938914\
uninstall cmd: MsiExec.exe /X{002D9D5E-29BA-3E6D-9BC4-3D7D6DBC735C}
MSXML 6 Service Pack 2 (KB954459) 6.20.1099.0 ({1A528690-6A2D-4BC5-B143-8C4AE8D19D96})
version: 101975115
version (major): 6
version (minor): 20
estimated size: 1369
install date: 20081212
install source: g:\511b041fecd8ac2a9946\
uninstall cmd: MsiExec.exe /I{1A528690-6A2D-4BC5-B143-8C4AE8D19D96}
help link: http://support.microsoft.com/kb/954459
Java(TM) 6 Update 14 6.0.140 ({26A24AE4-039D-4CA4-87B4-2F83216014FF})
version: 100663436
version (major): 6
estimated size: 97228
install date: 20090709
install location: C:\Program Files\Java\jre6\
install source: C:\Documents and Settings\Administrator\Application Data\Sun\Java\jre1.6.0_14\
uninstall cmd: MsiExec.exe /X{26A24AE4-039D-4CA4-87B4-2F83216014FF}
publisher: Sun Microsystems, Inc.
contact: http://java.com
help link: http://java.com
readme: C:\Program Files\Java\jre6\README.txt
J2SE Runtime Environment 5.0 Update 3 1.5.0.30 ({3248F0A8-6813-11D6-A77B-00B0D0150030})
version: 17104896
version (major): 1
version (minor): 5
estimated size: 146909
install source: http://java.sun.com/webapps/download/Ge ... dows-i586/
uninstall cmd: MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0150030}
readme: C:\Program Files\Java\jre1.5.0_03\README.txt
Java(TM) SE Runtime Environment 6 Update 1 1.6.0.10 ({3248F0A8-6813-11D6-A77B-00B0D0160010})
version: 17170432
version (major): 1
version (minor): 6
estimated size: 163726
install date: 20070510
install source: http://javadl.sun.com/webapps/download/ ... dows-i586/
uninstall cmd: MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160010}
readme: C:\Program Files\Java\jre1.6.0_01\README.txt
Java(TM) 6 Update 2 1.6.0.20 ({3248F0A8-6813-11D6-A77B-00B0D0160020})
version: 17170432
version (major): 1
version (minor): 6
estimated size: 136370
install date: 20070816
uninstall cmd: MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160020}
readme: C:\Program Files\Java\jre1.6.0_02\README.txt
Java(TM) 6 Update 3 1.6.0.30 ({3248F0A8-6813-11D6-A77B-00B0D0160030})
version: 17170432
version (major): 1
version (minor): 6
estimated size: 136430
install date: 20071020
uninstall cmd: MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160030}
readme: C:\Program Files\Java\jre1.6.0_03\README.txt
Java(TM) 6 Update 5 1.6.0.50 ({3248F0A8-6813-11D6-A77B-00B0D0160050})
version: 17170432
version (major): 1
version (minor): 6
estimated size: 139422
install date: 20080324
uninstall cmd: MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160050}
readme: C:\Program Files\Java\jre1.6.0_05\README.txt
Java(TM) 6 Update 7 1.6.0.70 ({3248F0A8-6813-11D6-A77B-00B0D0160070})
version: 17170432
version (major): 1
version (minor): 6
estimated size: 139514
install date: 20080914
uninstall cmd: MsiExec.exe /I{3248F0A8-6813-11D6-A77B-00B0D0160070}
readme: C:\Program Files\Java\jre1.6.0_07\README.txt
WebFldrs XP 9.50.7523 ({350C97B0-3D7C-4EE8-BAA9-00BCB3D54227})
version: 154279267
version (major): 9
version (minor): 50
estimated size: 2472
install date: 20070503
install source: C:\WINDOWS\system32\
help link: http://www.microsoft.com/windows
ATI Parental Control & Encoder 3.0 ({36CDA33B-909B-4719-97D1-C4B99309BDC7})
version: 50331648
version (major): 3
estimated size: 56
install date: 20080220
install location: C:\WINDOWS\system32\
install source: D:\Install Pack\ATIPCE\
uninstall cmd: MsiExec.exe /I{36CDA33B-909B-4719-97D1-C4B99309BDC7}
publisher: ATI Technologies Inc.
contact: Customer Support Department
help link: http://support.ati.com
help telephone: 1-905-882-2600
Adobe® Photoshop® Album Starter Edition 3.0 3.00.000 ({4BDFD2CE-6329-42E4-9801-9B3D1F10D79B})
version: 50331648
version (major): 3
estimated size: 16717
install date: 20070505
install location: C:\Program Files\Adobe\Photoshop Album Starter Edition\
install source: C:\WINDOWS\Downloaded Installations\{8379D168-79F6-4394-81A2-BB1944E8F892}\
uninstall cmd: MsiExec.exe /I{4BDFD2CE-6329-42E4-9801-9B3D1F10D79B}
publisher: Adobe Systems, Inc.
readme: C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\ReadMe.txt
AVIVO 9.14.0.60504 ({5399ACAF-7B15-43D5-9233-4E797B184FD2})
version: 151912448
version (major): 9
version (minor): 14
estimated size: 2692
install location: C:\Program Files\Common Files\ATI Technologies\Multimedia\
install source: D:\Install Pack\AVIVO\
uninstall cmd: MsiExec.exe /X{5399ACAF-7B15-43D5-9233-4E797B184FD2}
contact: From online registration through personal assistance, ATI Customer Care is focused on delivering accurate, up-to-date product support for optimum usability and performance.
help link: http://www.ati.com/support
Windows Live Messenger 8.1.0178.00 ({571700F0-DB9D-4B3A-B03D-35A14BB5939F})
version: 134283442
version (major): 8
version (minor): 1
estimated size: 31815
install date: 20070504
uninstall cmd: MsiExec.exe /I{571700F0-DB9D-4B3A-B03D-35A14BB5939F}
ATI Problem Report Wizard 8.10 ({5DA6F06A-B389-407B-BF8C-1548767914D8})
version: 134873088
version (major): 8
version (minor): 10
install location: C:\Program Files\ATI Technologies\PRW\
install source: D:\Install Pack\PRW\
uninstall cmd: MsiExec.exe /X{5DA6F06A-B389-407B-BF8C-1548767914D8}
comments: ATI offers a wide variety of product support including driver downloads, technical and warranty information.
contact: ATI Customer Support Department
help telephone: 1-905-882-2626
Adobe Acrobat and Reader 8.1.2 Security Update 1 (KB403742) 8.1.2 ({6846389C-BAC0-4374-808E-B120F86AF5D7})
version: 134283266
version (major): 8
version (minor): 1
estimated size: 8180
install date: 20080730
install location: C:\Program Files\Adobe\Security Update\
install source: C:\Documents and Settings\Toby Bibeau\Local Settings\Application Data\Adobe\Updater5\Install\reader8rdr-en_US\
uninstall cmd: MsiExec.exe /X{6846389C-BAC0-4374-808E-B120F86AF5D7}
comments: Your Comments
help link: http://www.Adobe.com
help telephone: 1-555-555-4505
Microsoft Visual C++ 2005 Redistributable 8.0.56336 ({7299052b-02a4-4627-81f2-1818da5d550d})
version: 134274064
version (major): 8
estimated size: 5330
install date: 20090616
install source: C:\DOCUME~1\TOBYBI~1\LOCALS~1\Temp\AVGDownloadManager\packages\51\
uninstall cmd: MsiExec.exe /X{7299052b-02a4-4627-81f2-1818da5d550d}
Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053 8.0.50727.4053 ({770657D0-A123-3C07-8E44-1C83EC895118})
version: 134268455
version (major): 8
estimated size: 109
install source: i:\a703652b57f3a781c5b2e4876f946d08\
uninstall cmd: MsiExec.exe /X{770657D0-A123-3C07-8E44-1C83EC895118}
Ventrilo Client 3.0.5 ({789289CA-F73A-4A16-A331-54D498CE069F})
version: 50331653
version (major): 3
estimated size: 4540
install date: 20090819
install source: C:\Program Files\Common Files\Wise Installation Wizard\
uninstall cmd: MsiExec.exe /I{789289CA-F73A-4A16-A331-54D498CE069F}
publisher: Flagship Industries, Inc.
help link: http://www.ventrilo.com
Windows Support Tools 5.1.2510.0 ({8398B542-3CC4-44D9-83DF-696CCE70124B})
version: 83954126
version (major): 5
version (minor): 1
estimated size: 13040
install date: 20080809
install source: C:\Documents and Settings\Toby Bibeau\Desktop\WinXPPro\SUPPORT\TOOLS\
uninstall cmd: MsiExec.exe /I{8398B542-3CC4-44D9-83DF-696CCE70124B}
Microsoft Office Professional Edition 2003 11.0.8173.0 ({90110409-6000-11D3-8CFE-0150048383C9})
version: 184557549
version (major): 11
estimated size: 1053705
install date: 20090813
install source: C:\MSOCache\All Users\90000409-6000-11D3-8CFE-0150048383C9\
uninstall cmd: MsiExec.exe /I{90110409-6000-11D3-8CFE-0150048383C9}
help link: http://www.microsoft.com/support
readme: C:\Program Files\Microsoft Office\OFFICE11\1033\OFREADME.HTM
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 9.0.30729 ({9A25302D-30C0-39D9-BD6F-21E6EC160475})
version: 151025673
version (major): 9
estimated size: 10524
install source: i:\966562470ea24dc94d8245b40c8ddc\
uninstall cmd: MsiExec.exe /X{9A25302D-30C0-39D9-BD6F-21E6EC160475}
Brother MFL-Pro Suite 1.00 ({9A912C12-A7DA-44D7-BD57-5CA85E2F33E1})
version: 16777216
install date: 20070904
install location: C:\Program Files\Brother\Brmfl06a
uninstall cmd: RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\PROFES~1\RunTime\11\00\Intel32\Ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9A912C12-A7DA-44D7-BD57-5CA85E2F33E1}\Setup.exe" -l0x9 Brunin03.dll -removeonly
publisher: Brother Industries, Ltd.
Microsoft .NET Framework 3.0 Service Pack 2 3.2.30729 ({A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7})
version: 50493449
version (major): 3
version (minor): 2
estimated size: 184293
install date: 20090611
install source: C:\DOCUME~1\TOBYBI~1\LOCALS~1\Temp\dotnetfx3530729.01\1033\dotnetfx30\
uninstall cmd: MsiExec.exe /I{A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}
help link: http://go.microsoft.com/fwlink/?LinkId=98075
({A3051CD0-2F64-3813-A88D-B8DCCDE8F8C7}.KB958483)
Adobe Reader 8.1.2 8.1.2 ({AC76BA86-7AD7-1033-7B44-A81200000003})
version: 134283266
version (major): 8
version (minor): 1
estimated size: 88543
install date: 20080615
uninstall cmd: MsiExec.exe /I{AC76BA86-7AD7-1033-7B44-A81200000003}
comments:
help link: http://www.adobe.com/support/main.html
Toby B.
Postby Toby B. » Fri Aug 21, 2009 12:08 pm
Hijackthis Log:
Logfile of HijackThis v1.99.1
Scan saved at 3:58:26 PM, on 8/21/2009
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16876)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\CAPPActiveProtection.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
C:\Program Files\Crimson Editor\cedt.exe
C:\Program Files\Internet Explorer\iexplore.exe
R3 - URLSearchHook: (no name) - CFBFAE00-17A6-11D0-99CB-00C04FD64497} - (no file)
R3 - URLSearchHook: (no name) - EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: (no name) - {201f27d4-3704-41d6-89c1-aa35e39143ed} - (no file)
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - (no file)
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: (no name) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - (no file)
O2 - BHO: (no name) - {A3BC75A2-1F87-4686-AA43-5347D756017C} - (no file)
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O2 - BHO: (no name) - {F0F61477-5546-4E96-8A14-0C2FC134DAC2} - (no file)
O2 - BHO: SingleInstance Class - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\YTSingleInstance.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O3 - Toolbar: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [BrMfcWnd] C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN
O4 - HKLM\..\Run: [SetDefPrt] C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe
O4 - HKLM\..\Run: [ControlCenter3] C:\Program Files\Brother\ControlCenter3\brctrcen.exe /autorun
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe"
O4 - HKLM\..\Run: [LoadMSvcmm] "C:\Program Files\Blockbuster\BLOCKBUSTERMovielink\Movielink User.exe"
O4 - HKLM\..\Run: [cctray] "C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe"
O4 - HKLM\..\Run: [CAVRID] "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe"
O4 - HKLM\..\RunOnce: [Spybot - Search & Destroy] "C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe" /autocheck
O4 - HKLM\..\RunOnce: [SpybotDeletingA6982] command /c del "C:\WINDOWS\system32\drivers\hjgruinscurtbe.sys"
O4 - HKLM\..\RunOnce: [SpybotDeletingC6342] cmd /c del "C:\WINDOWS\system32\drivers\hjgruinscurtbe.sys"
O4 - HKLM\..\RunOnce: [SpybotDeletingA3766] command /c del "C:\WINDOWS\system32\hjgruighqewhbw.dll"
O4 - HKLM\..\RunOnce: [SpybotDeletingC7558] cmd /c del "C:\WINDOWS\system32\hjgruighqewhbw.dll"
O4 - HKLM\..\RunOnce: [SpybotDeletingA664] command /c del "C:\WINDOWS\system32\hjgruikuppnsch.dll"
O4 - HKLM\..\RunOnce: [SpybotDeletingC5676] cmd /c del "C:\WINDOWS\system32\hjgruikuppnsch.dll"
O4 - HKLM\..\RunOnce: [SpybotDeletingA8383] command /c del "C:\WINDOWS\system32\hjgruincpbjumw.dat"
O4 - HKLM\..\RunOnce: [SpybotDeletingC4106] cmd /c del "C:\WINDOWS\system32\hjgruincpbjumw.dat"
O4 - HKLM\..\RunOnce: [SpybotDeletingA8879] command /c del "C:\WINDOWS\system32\hjgruiovubxmhx.dat"
O4 - HKLM\..\RunOnce: [SpybotDeletingC1714] cmd /c del "C:\WINDOWS\system32\hjgruiovubxmhx.dat"
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/Shar ... vSniff.cab
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O16 - DPF: {4871A87A-BFDD-4106-8153-FFDE2BAC2967} (DLM Control) - http://dlm.tools.akamai.com/dlmanager/v ... .2.4.3.cab
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/Shar ... /cabsa.cab
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object) - http://go.divx.com/plugin/DivXBrowserPlugin.cab
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/microso ... 0680954281
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/s ... wflash.cab
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\
O20 - Winlogon Notify: ddcCvuVP - C:\WINDOWS\
O20 - Winlogon Notify: dimsntfy - C:\WINDOWS\
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Acronis Scheduler2 Service (AcrSch2Svc) - Acronis - C:\Program Files\Common Files\Seagate\Schedule2\schedul2.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: CaCCProvSP - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
O23 - Service: CAISafe - Computer Associates International, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
O23 - Service: FAH@C:+folding+FAH504-Console.exe - Stanford University - C:\folding\FAH504-Console.exe
O23 - Service: CA Pest Patrol Realtime Protection Service (ITMRTSVC) - CA, Inc. - C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Unknown owner - C:\Program Files\Java\jre6\bin\jqs.exe" -service -config "C:\Program Files\Java\jre6\lib\deploy\jqs\jqs.conf (file missing)
O23 - Service: Movielink Core Service - Blockbuster - C:\PROGRA~1\BLOCKB~1\BLOCKB~1\MovielinkCore.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: PPCtlPriv - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
O23 - Service: VET Message Service (VETMSGNT) - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
O23 - Service: Yahoo! Updater (YahooAUService) - Yahoo! Inc. - C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
Toby B.
Postby evasive » Fri Aug 21, 2009 12:57 pm
All I can tell you if you have indeed that dreaded AntiVirus2009 or one of its spinoffs, chances are you want to get out your windows/programs CDs, make a backup of your stuff now and start anew. Once you have your windows+programs+updates in order, make an image of the harddisk, saves you a lot of time when the next infection occurs...
