virus removal
Help and Discussion
virus removal
Postby DpR228 » Thu Jun 04, 2009 11:35 am
I'm looking for a good program that will remove viruses from my computer...i ran a few scanners and all of them said i had viruses but would not remove them...i tried avg, and malware but neither one helped...any suggestions?
DpR228
Postby Mr T » Thu Jun 04, 2009 12:47 pm
Don't waste your time, it is far easier to back up, format and reinstall windows - this eradicates all virus activity, gives you a clean slate to start off and generally a far quicker system... Only try to remove it, if you have applications you need with big, big save files....
I say this because I have spent too much time p***ing about trying to remove a virus and in the same space of time, I could have backed up my files to a USB drive, formatted and reinstalled windows, drivers and applications, then put the files back on...
Postby DpR228 » Thu Jun 04, 2009 9:13 pm
well i bought the computer used and it didn't have a os cd...also i don't have hardly any files on my computer....do you still think it would be best to buy an os and reinstall?
DpR228
Postby pbailey » Thu Jun 04, 2009 9:31 pm
Have you tried this:
http://download.bleepingcomputer.com/ma ... -setup.exe
and Spyware Dr. through google pack:
Un-check all but Spyware Doctor, update and run a full scan!
http://pack.google.com/intl/en/pack_installer.html
Make sure AVG is updated!
Paul
pbailey
Postby Mr T » Fri Jun 05, 2009 10:51 am
.. Ouch!... However it may have a recovery partition (ie gateway, medions, compaqs and some dells do - you have to hit something like ALT and F11 at startup).... If you do try any scanners, always run them in SAFE MODE (press F8 before the windows splash screen)...
Postby bdub » Fri Jun 05, 2009 12:00 pm
i agree that reformatting might be the best answer in most cases. in this case you either...
need to buy windows, backup and reinstall,
fix the viral problems you have,
OR this seems like a good time to backup and switch to windows 7, yes?
the release candidate is free, and will be allowed to run at least until next march, and possibly all the way to september of 2010, without any hitches. if anything, you get a quicker system with a fresh windows install, plus you get a good amount of time to put together money to buy the new OS when it's released.
read more here...
http://www.microsoft.com/windows/window ... nload.aspx
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby TriAngle » Sun Jun 21, 2009 4:27 pm
I'm running Windows 7 RC. SUPERAntiSpyware (http://www.superantispyware.com) doesn't work on 7. Malwarebytes' Anti-Malware works fine (http://www.malwarebytes.org/mbam.php).
Am also using Comodo's Internet Security - Firewall and AntiVirus (http://www.comodo.com/products/free_products.html).
These are free programs, fully functional.
They work fine, no problems.
TriAngle
