It is currently Sat Sep 22, 2018 5:15 pm
 Post subject: Problem with Kerio
PostPosted: Sat Dec 13, 2008 9:41 am
I downloaded the trial version of Kerio and for the most part it meets my needs. However there are web pages which it blocks and will not proceed even when I try to over ride. I am using their default for over rides of Windows + P. These are sites I have always checked into before with no problems. Is there away around the blockage except uninstalling Kerio and finding another firewall?
PostPosted: Sat Dec 13, 2008 2:34 pm
Ensure that only one Firewall program is active. If two are active at the same time, then there will be conflicts.
The program may not show a message box about what action to take with each site newly visited.. and may form a "blanket" block on sites it deems not 100% safe for all viewers (a form of 'parental guidance').
Bring up the program box from the SysTray area, and check for the permissions as to site IP addresses.
