Need Help!!!!VIRUS
Help and Discussion
Postby bdub » Fri Nov 14, 2008 6:03 pm
i think you need to turn off system restore while in regular mode, then reboot into safe mode...
but a hijackthis report would be good, too.
http://www.download.com/Trend-Micro-Hij ... 27353.html
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby TheNeophyte » Thu Nov 27, 2008 3:01 pm
Karlsweldt wrote:The wrong editing of Registry keys can cause the OS to go belly-up!
Thanks I will try my best, but in terms of editing the registry I am not sure about it. I am using tune up in order to correct my registry. Most probably I will just consult it to the specialist here.
thank again.
To Live is for something, To Die is for nothing
TheNeophyte
Postby TriAngle » Wed Dec 03, 2008 3:12 pm
BACKUP the Registry first and foremost!
You don't get another chance if you whack it up!
Follow these guys instructions. We've all been there before.
I use CCleaner to delete extraneous crud in the Registry. http://www.ccleaner.com (FREEWARE).
Good luck.
Tri. PDT_Armataz_01_01
TriAngle
Previous
