It is currently Tue Sep 25, 2018 3:23 am
 Post subject: Loading pages twice
PostPosted: Tue Sep 30, 2008 10:19 pm
Most of the time I have to click links two and three times before the page will load. Some times the page loads but it is all HTML text until I click refresh. It happens with all versions of firefox. I use IE to log into my netflix page and IE freezes up 6 times out of ten when trying to load the page.
I have ran all the anti-spyware programs I can find and they tell me I'm clean. I have ran AVG8 and Avast antivirus and they tell me I'm clean so I don't think it's a virus or spyware.
On this PC I am running Kerio personal firewall. I have noticed the ALG.EXE file running in task manager and I wonder if this needs to run when I'm not using internet connection sharing or the windows firewall.
I'm not sure when this started. Four things happened around the same time. I upgraded to AVG 8, I bought a new router, Service pak 3 and Firefox 3 came out.
As for the router; My PC is the only one on my network having any problems but it is the only one running Kerio. I have change back to Firefox 2.0**. and I have removed AVG8 and installed Avast.
Any thoughts?
It's always funny until someone loses an Operating System!
PostPosted: Wed Oct 01, 2008 5:18 am
You could try changing Kerio for the windows firewall just to see if that helps. When was the last time you checked your patch cords?
PostPosted: Wed Oct 01, 2008 6:50 am
I will try uninstalling Kerio later tonight. I have used Kerio for about 6 years and don't know if I can live without it. :-| I don't think the Windows firewall gives me much in the way of security though. I have an extra patch cord to try also.
PostPosted: Wed Oct 01, 2008 11:13 am
I didn't say that would be a permanent solution, I'm merely trying to exclude things, if Kerio is acting up, maybe they have an update or patch, who knows.
PostPosted: Wed Oct 01, 2008 6:25 pm
Well the check for updates button within the software said there were no updates available. I decided to check at their website anyway and guess what; There have been a lot of updates. So I've downloaded the latest version and that seems to have improved the Firefox issue I've only had to click one site's link twice but I think that's normal once in a while.
When loading Netflix; IE was locking up and needed to be manually closed to continue. After the update; I load my Netflix page and it seemed to lock up but after 20 seconds or so it finished loading.
I think I'm all set. It looks like the update was the answer! I feel like an airhead for not checking their website first.
Thanks evasive
PostPosted: Thu Oct 02, 2008 12:41 am
Ha! And guess how I come to ask this question. Been there, done that although different issue and other trivial solution. :)
