It is currently Mon Aug 20, 2018 10:56 am
PostPosted: Thu Jul 03, 2008 4:28 am
Currently running Spybot S&D v1.5.2 Just installed the new version of Adaware 2008 v 7.1.0.10. I went to open Spybot and got a pop up saying that I had Adaware installed and that there may be a conflict between the two. I never had got this warning before.
Is there something going on now between these two utilities ? Do they no longer get along with each other?
PostPosted: Fri Jul 04, 2008 12:22 am
If you read the message carefully you will see they say it MIGHT conflict. They overlap in sections. That is all.
PostPosted: Sat Jul 05, 2008 10:08 am
I have both programs installed on my computer and they run fine. Don't run both together at the same time.
Intel Core 2 Duo E6750 3.8ghz
8800 GTS 640MB
Crucial Ballistix 2GB DDR2 800
Gigabyte DS3R
PostPosted: Sat Jul 05, 2008 12:46 pm
Yep, one after the other is fine. If you run them at the same time they might fight over who gets to kill the bad file :)
