AVG Not Updating ?????
Help and Discussion
Postby Spark » Sun Jun 29, 2008 10:19 pm
This concerns the new version of AVG free, version 8.0.101
I have used previous versions of AVG in the past but for some reason this new version does not seem to be updating like the previous free version. 2 weeks have gone by and no new definition updates are available? This sounds odd as it used to update almost every day.
Spark
Postby kylepaddock » Mon Jun 30, 2008 6:49 am
I have that and it works fine. make sure that you still do not have AVG7. you mght want to re-instal it.
Gateway MT6707 Notebook
Intel Pentium Dual Core T2060 1.6 GHz
Memory 2048 MB 533MHz DDR2 SDRAM
Intel Graphics Media Accelerator 950
224 MB shared video memory
High definition audio 2 channel
160 GB HD
8X Multi-format dual layer optical drive
802.11g wireless LAN
4 USB 2.0 ports
One VGA port
One S-Video
One IEEE 1394
One PCMCIA Slot
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
kylepaddock
Postby RockyAMD » Sat Jul 05, 2008 10:09 am
Its been awhile for my avg also, haven't had any updates in awhile, but its still running fine.. Don't worry :D
Intel Core 2 Duo E6750 3.8ghz
8800 GTS 640MB
Crucial Ballistix 2GB DDR2 800
Gigabyte DS3R
RockyAMD
Postby evasive » Sat Jul 05, 2008 12:47 pm
every now and then I do run a manual update to check, but no new updates.
Postby TriAngle » Mon Oct 27, 2008 5:14 am
i recently installed the free AVG onto a system, and it would not update until it was registered.
hmmmmmmmmmmmm
after that, it updated fine.
Tri.
TriAngle
Postby Mr T » Sun Dec 07, 2008 12:30 am
1565:AVG update issue - Invalid update control CTF fileIf you receive the "Invalid update control CTF file" message during AVG update, most probably the update control files are corrupted. In this case it is necessary to delete these files. During a next attempt to update AVG, new control files should be downloaded and update process should be completed without any difficulties. Please kindly follow these steps to delete mentioned control files:
Download the utility from the link below to your hard drive
deleteupdatefiles.exe
Run the downloaded utility (command line window will appear for a short time)
Try to update the AVG program
If the issue persists, then please follow steps below:
Double-click the My computer icon on your desktop (or open Start -> My Computer)
Navigate to the following folder:
Windows XP / 2000:
C:\Documents and Settings\All Users\Application Data\avg8\update\download *
Windows Vista:
C:\ProgramData\avg8\update\download *
Find the avginfoavi.ctf and avginfowin.ctf files and delete them
Restart your computer
* Please note that some folders/files could be hidden. For more information how to view these hidden folders/files please visit this FAQ: How to view hidden files and folders
Your Internet settings are not correct.
Even if your Internet connection is working correctly, incorrect DNS servers may be filled in, affecting AVG update. This can be caused e.g. by some virus that was previously on your computer.
Open menu Start -> (Settings) -> Control Panel.
Double-click on Network connections.
Right-click on the connection you are using and choose Properties.
Double-click on Internet Protocol (TCP/IP) item on the General tab.
Please check (and modify if necessary) the settings of IP address and DNS servers according to your Internet Provider settings or choose the Obtain * * DNS server address automatically option.
Confirm the settings by clicking on the OK button.
Close the window.
If the issue persists even after performing the steps above, please contact us using the Get Help Online option in AVG Help menu.
Courtesy of Grisoft... However it is easier to uninstall AVG, download the latest from filehippo and install that....
Postby snakebite66 » Sun Dec 07, 2008 11:50 am
Yep...mine gone 'pear shaped'...
downloading new version from good old Filehippo...
Benjamin Franklin (1706-1790)
snakebite66
Postby Karlsweldt » Sun Dec 07, 2008 3:17 pm
The AVG version 7.5 will not be supported after December 31. The new version 8.0 will need to be installed (or upgraded to). I have a 3-station license for my program(s).
AVG is more 'transparent' than McAFee was. And so much more compatible to other programming than Symantec!!
A few weeks back, I had a deal where the AVG wanted to reboot with every daily update. The same quote as from Mr T applied. Since then, no problems.
