Tyan Thunder K7X - AGP PRO slot!
Postby Hardware Junkie » Fri May 10, 2002 6:43 pm
I was browsing Tyan's site when I noticed a new board in the MPX area:
http://www.tyan.com/products/html/thunderk7x.html
This board is equiped with an AGP Pro slot, a 5volt 64bit PCI slot, and a 3.3v 64bit PCI slot!!!!
I mean holy snapping crap! 8O 8O 8O :!: :!:
Postby Tolemac » Fri May 10, 2002 7:03 pm
Ok, I understand 66MHz 64bit PCI slot, but what does the 3.3volts bring to the table? What cards will benefit from this slot?
Tolemac
Postby len444 » Mon May 13, 2002 4:05 pm
:arrow: :idea: pci slots:1)5v 64 bit @ 33mhz, and 2)3.3v 64 bit and 66mhz-
can stick (i believe) a 32 bit 33mhz pci card into the 33mhz 64bit slot, but not into the 3.3v 66mhz, 64bit pci slot
http://www.motherboards.org/articlesd/m ... 171_2.html
len444
Return to The Water Cooler
