It is currently Sun Oct 25, 2020 7:36 pm
Post new topic Reply to topic  [ 119 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12
PostPosted: Wed Oct 18, 2006 5:43 am
If we're talking about an internet connection, the average hard drive can max out a cable connection easy. Why bother with a RAID?
Now, if you're just transferring within the network on a gigabit connection, then RAID will begin to boost performance.
RIAA vs The People
PostPosted: Tue Dec 19, 2006 9:49 pm
Heh...
well, it took me awhile to actually get this done (totally my fault), but I had the front panel of my case replaced recently.
I contacted the case manufacturer on the slight chance they might do something. I didn`t want to use the store I got it from, because they were so painfully slow, and probably had no-one who spoke English. The case company was so nice about everything. They asked me to trouble shoot a couple of things first, then told me to mail the front panel collect. They sent back a new front panel within a few days with a nice letter apologizing for the trouble. Now the LCD is working beautifully...
now the next issue is, should I plug more fans into it just so I have more to monitor on the LCD hahahahah
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
PostPosted: Tue Oct 09, 2007 11:04 am
Ryn, did you get rid of your sweet water cooling setup? :(
Main rig: 1/2" ID Water Cooled Lian-Li V2000B, Abit IP35 Pro, Intel C2D [email protected] -3.4ghz 1.3375v, Mushkin 2gb DDR2-800 996576, one terabyte storage, evga 7900GS KO w/ Zalman VF700-AlCu cooler, Swiftech Apogee GT water block, Ultra X2 550w PSU
Laptop: Asus Z70VA, Pentium M 725 [email protected] -2.13ghz (pinmod), ATI X700 Pro, 1680x1050 native res., bluetooth, the works...
PostPosted: Wed Oct 10, 2007 1:42 am
Unfortunately, yes. One of the pump had an electrical failure of some sort and affected the other pump as well. I might rebuild it in the near future if I find some time and make a better external case for it :wink:
Join the Motherboards.org Folding Team 33258
 Post subject: my main unit
PostPosted: Mon Dec 17, 2007 10:29 pm
Areocool masscool, Intel 955xcs btx mainboard intel 3.0 pentium d dual core cpu,and 4 gig of pc2 533 ramwill be upgrading to 64 bit os so as to be able to take advantage of 8 gig ddr2 667 ram Diablo 512 vid sli,thermaltake 735 kit with a 120mmx240mm rad., 32" lcd tv monitor, 2 750 gig sata300 hdd, lightscribe dvd burner, dvd rom and remote media controler
Last edited by Michaelapctech on Mon Jan 28, 2008 12:42 am, edited 2 times in total.
PostPosted: Mon Dec 24, 2007 3:39 am
Current system:
AMD Athlon 64 3200+, MSI K8N Neo2, 1.5Gb DDR400, Asus 6800GT AGP, Maxtor 300Gb IDE, WD 120Gb IDE, Seagate 80Gb IDE, NEC DVD-RW, 400W FSP PSU, Beantech Igloo 3, 20" LG L204WT Widescreen Monitor.
Planned system (Jan/Feb 2008):
Intel Core 2 Duo E6750, Abit IP35 Pro, 2Gb Corsair TwinX XMS2 DDRII 800, Sapphire HD 3870 512Mb PCI-E, Samsung 500Gb SATA, Maxtor 300Gb IDE, WD 120Gb IDE, Samsung Lightscribe DVD-RW, Sharkoon Rebel 12 Economy black, Zalman 600W Heatpipe PSU, 6x Sharkoon Silent 2000 120mm fans.
Haven't decided on which HSF yet. Either Thermalright Ultra-120 eXtreme with 2 fans (push-pull) or something similar.
:D
PostPosted: Fri Feb 22, 2008 9:02 pm
Gaming Rig: Q6600 2.4Ghz, 8GB DDR2 800, 160GB HD, 8800GTS 640MB, Vista Home Premium 64-bit,
Lan Rig: E4500 C2D 2.2Ghz, 2GB DDR2 533, 500GB HD, ATI x1650, XP Pro
Server: Mac Pro, 8 cores 2.8Ghz Penryn, 8GB DDR2 667, 320GB HD, 3x750GB HDs, 8800GT, OS X Leopard Server, (eventurally I will upgrade to 16GB of ram, when I have the money)
Laptop: MacBook, 2ghz C2D, 950 Intagrated, 2GB DDR2 667, 80GB HD, OS X Leopard, (soon to upgrade to a 250GB Hard Drive)
I'm going to post pictures when I get everything setup in my new computer room in my house (my mom's letting me take over the guest bedroom and convert it into a computer lab)
I should be buying the Mac Pro tomorrow, and I'm ordering the additional hard drives and ram from Newegg in a few days. This tower is going to be used for video editing, college, and for learning how to use a server Operating System ^_^
(and to everyone who is wondering: Yes, I am quite insane about my computer purchases)
People who have gone through Starfleet academy should be taught how to fix everything. Even a Roman aqueduct.
PostPosted: Sun Mar 09, 2008 1:30 pm
Hey guys. Anyone remember me? :P
I keep forgetting this place... Anyway, I'm back, and with a kickass PC. 8)
(I'm basically just gonna copy what DXDIAG tells me...)
Processor: AMD Athlon(tm)+ 64 X2 Dual Core Processor 6400+, MMX, 3DNow (2 CPUs) - 3.2 GHz
Memory: 3326 MB (3.326 GB)
Graphics card: NVIDIA GeForce 8800 GTX with 768 MB of memory
Harddrive: 232 GB
OS: Windows XP
Wish I'd had Vista now, as I can't have DX10 on Crysis. :(
PostPosted: Mon Jan 11, 2010 5:54 pm
Let's see who has some of the best monitor setups....
I've got 2x NEC E700 @ 1600*1200.
(now to get a card so I can actually use the two monitors, maybe a 3rd....)
Users browsing this forum: No registered users and 14 guests
