It is currently Wed Sep 23, 2020 6:08 pm
 Post subject: Tablets
PostPosted: Mon May 29, 2017 11:05 pm
It's been a while (about a little more than 3 years) since I bought my first tablet, an iPad. Right off the bat it reminded me of one of my very first PC's a Dell. My experience with my Dell was a total nightmare of the company. Almost everything was proprietary and I see that with my Apple IPad.
While looking up the next version of the iPad I came across an article that said over the last few years the iPad has been going out of flavor and that the Android OS is more popular.
What I did find out from using the iPad is that it didn't pick up any nasties like my Windows XP did once in a while. What makes the Android OS so much better that buyers would favor tablets running it.? The same I guess holds true with iPhone smart phones.
Are tablets and smart phones running the Android OS subject to viruses like Windows are? If not the Android OS what makes the real reason that makes Android running tablets more popular than Apples? Is it the cost $$$$$ factor. No getting away from the fact that a new iPad can set one back $600 bucks if not more. Or is it something else which is my question here???
KEEP AMERICA GREAT
 Post subject: Re: Tablets
PostPosted: Thu Feb 01, 2018 1:50 pm
You answered the question by yourself, Android is much more flexible for installing any application, upgrades, etc.
my son says that he feels like his ipad is rented from apple, not owned by him, unless you do some jailbreaking work
-Wrapped Around Your Fingers-
-The Police-
PostPosted: Wed Feb 21, 2018 4:12 am
No matter what the label, both are planned landfill items without any options for upgrades. Such is the world that we live in these days. Cradle to cradle my @ss....
PostPosted: Mon Jul 01, 2019 3:18 am
Yeah it's true pads are not worth the money and usually, they get slower and laggy after every os update and release of new iPad versions, on the other hand android tablets are 90% compatible with new apps and they don't lag like ipad.
PostPosted: Thu Aug 08, 2019 5:49 pm
Apple runs on a closed platform with the expectation of the end user using a particular device for a limited amount of time via software updates. There is no way to downgrade the device or keep the device usable without retaining the SHSH blobs or original firmware. By then most applications will be updated and will be no longer compatible with the older software version, thus forcing you to update and then facing the consequences of a slower device in order to purchase a new device. However, on the android side, most manufacturers build relatively good devices with good specs and android is more open, thus allowing for downgrades via USB ADB and also with a high developer scene allows for maximum potential usage of a device beyond the manufacturer's intended use and limit for the device, ex. custom roms, tweaks, apps, and other goodies.
Kind Regards,
AJ23ZX
