It is currently Wed Jan 16, 2019 12:20 am
PostPosted: Wed Apr 29, 2015 4:42 pm
Using a programs called Types I have finally been able to add custom filetype associations(including icons too, and having more then JUST A MERE DEFAULT one =()
http://ystr.github.io/apps/types/
http://ystr.github.io/apps/types/new.rss <-- Changelog
The example is:
  • .xml
  • XML Document
I add two
Edit /w Notepad 2
Open w/ Firefox <-- replaces the default Open with Internet Explorer..
but I found two other entries on the context menu that should NOT exist!
=( and they are wasting space on my context menu.... X(
"Open" and "Edit", both open with the original Notepad.. uggh X(
Quote:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\xmlfile]
@="XML Document"
"EditFlags"=hex:00,00,01,00
"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\ <-- = "@%SystemRoot%\System32\msxml3r.dll,-1"
00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
32,00,5c,00,6d,00,73,00,78,00,6d,00,6c,00,33,00,72,00,2e,00,64,00,6c,00,6c,\
00,2c,00,2d,00,31,00,00,00
[HKEY_CLASSES_ROOT\xmlfile\BrowseInPlace]
[HKEY_CLASSES_ROOT\xmlfile\CLSID]
@="{48123BC4-99D9-11D1-A6B3-00C04FD91555}"
[HKEY_CLASSES_ROOT\xmlfile\DefaultIcon]
@="C:\\Windows\\System32\\msxml3.dll,0"
[HKEY_CLASSES_ROOT\xmlfile\shell]
@="Edit_w/_Notepad_2"
[HKEY_CLASSES_ROOT\xmlfile\shell\Edit_w/_Notepad_2]
@="Edit w/ Notepad 2"
"icon"="C:\\Program Files\\Notepad2\\Notepad2.exe,0"
[HKEY_CLASSES_ROOT\xmlfile\shell\Edit_w/_Notepad_2\command]
@="\"C:\\Program Files\\Notepad2\\Notepad2.exe\" \"%1\""
[HKEY_CLASSES_ROOT\xmlfile\shell\Open_w/_Firefox]
@="Open w/ Firefox"
"icon"="C:\\Program Files\\Mozilla Firefox\\firefox.exe,0"
[HKEY_CLASSES_ROOT\xmlfile\shell\Open_w/_Firefox\command]
@="\"C:\\Program Files\\Mozilla Firefox\\firefox.exe\" \"%1\""
why they exist and how to get rid of them..
those two context menu entries are BLOAT, waste of space, etc....
(PC Specs)
CPU: AMD FX-9590 4.7GHz 8-core
CPU Instructions: MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Motherboard: Asus SABERTOOTH 990FX R2.0
GPU: nVidia GTX 1070 Ti 8GB
GFX Drivers: Nvidia v416.94
OS: Windows 7 Ultimate 64-bit SP1
RAM: 32GB Kingston 1866MHz DDR3
PostPosted: Thu Apr 30, 2015 4:54 pm
Maybe this will help..
http://windows.microsoft.com/en-us/wind ... =windows-7
Windows needs an "association" with files and the program used for their specific use.. such as CDA, MP3, gif, jpg, rtf, txt.
A lot of feature programs cannot be removed or disabled from Windows.
Most software programming that is intended to replace a Windows program does an automatic Registry edit to reflect the preference over the default program. Some have a user menu to select what files to associate or not associate with.
PostPosted: Thu Apr 30, 2015 5:41 pm
in your case what OS are you running in terms of windows?
why don't you try out types its a great program that is is more or less a work in progress ^_^..
That link might help me in a different sense... I couldn't recall how or where I disabled the crappy Windows built in search functionality on my Windows 7 laptop when i set it up.... I found I like Agent Ransack for searching it like XP but much better... I might have disabled the file indexing too.... ?_?
http://www.mythicsoft.com/agentransack/history
(PC Specs)
PostPosted: Fri May 01, 2015 5:08 am
Will check for you when in the office again, don't have a windows 7 machine at hand here. I have been playing around with Agent Ransack and FTA's before, should be able to give you some pointers or the registry keys that need to be changed.
PostPosted: Fri May 01, 2015 5:35 am
My 'daily driver' is still using Win XP Pro. Secondary or reserve system is Win XP Home.
My semi-dedicated F@H rig is running Win 7. Yes, will have to upgrade #1 and #2 someday.. when XP is "over the cliff".
One of my favorite programs is Total Commander from www.ghisler.com/ which is an excellent file manager/editor/viewer. Very easy to set associations with almost any file type. But leave the OS critical files alone.. they are tagged with attributes such as (s) for system, (h) for hidden or (r) for read only. (a) is for archive, common for many non-critical files.
