It is currently Fri Feb 28, 2020 12:37 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Apr 09, 2014 2:08 pm
Roach412 wrote:
...simply put, the operator is completely detached from the thing - it gives rise to issue that pilot responsibility is compromised when you're no longer physically "at-risk" of a failure, or stupid pilot error...or intentional destructive desires....
You make a good point. There's an old joke in aviation that the reason they put the cockpit in the nose of the plane is so the pilots will be the first to arrive at the scene of the crash. It generally is believed that it's MUCH more stressful to be an ATC controller than to be a pilot, because when a pilot REALLY screws up, his troubles are over. If a controller really flubs it, his nightmare has only begun.
Karlsweldt, the requirement to have a transponder doesn't come from a/c size, it comes from the type of operation and the type or airspace being flown in. The more restrictive of the two applies. Scheduled passenger air carriers operate under Part 121 or 135 of the FARs, both of which require a minimum of a Mode C transponder, which must be in operation any time the a/c is in motion, regardless of airspace. But if it's a training flight, and there are no ticketed passengers on board, the same a/c operates under Part 91 of the FARs, which governs General Aviation, and which has no overarching requirement to have a transponder. You can fly an 800,000# Boeing 747 under Part 91 without a transponder, but you can't fly an ultralight into JFK (Class B airspace) without a Mode C transponder (and a flight plan).
And I think you misunderstand the way a "plain jane" (Mode A/C) transponder operates. They do not communicate amongst themselves, and they do not transmit preemptively. They wait for an ATC radar to interrogate them, then they reply with the 4-digit code. All Mode A does is give ATC the ability to assign a unique identifier to a blip on the radar screen. It does nothing to aid in traffic separation or collision avoidance (excepting that ATC can provide it, based off radar & transponder information). Unless it's an AWACS or an electronic warfare platform, no other a/c has the capability to detect whether any particular a/c has a transponder in operation.
A Mode C transponder is a Mode A that also has altitude encoding. The only thing it does differently from a Mode A is it includes the pressure altitude reading from the a/c's altimeter along with the 4-digit code. ATC's surveillance radars are completely unable to judge an a/c's altitude and must rely on Mode C. But a Mode C-equipped transponder does nothing to improve on Mode A's failure to provide traffic separation or collision avoidance.
Some a/c (like the Piper Cub) have no transponder because their engine has no alternator. Older GA a/c generally have a Mode A transponder. Commercial and business a/c, and more recent GA a/c (pretty much the overwhelming majority of everything that flies) will have a Mode C transponder. It's only when you get to the tip of the iceberg that you'll find any a/c with an active collision avoidance system, like the TCAS (which I made reference to in an earlier post in this thread).
There is a thing called a Mode S transponder, which does provide traffic separation and collision avoidance, but that isn't a transponder in the traditional sense, it's a hybrid device, a Mode C transponder merged with TCAS-like equipment. Mode S isn't in widespread use, and probably won't ever be, because of what's coming down the pike.
There is a GPS-based system in the wings, called Automatic Dependent Surveillance-Broadcast, which sounds tailor-made for UAVs, especially autonomous ones, especially since its coverage isn't so degraded as radar's when flying close to the ground. Basically anywhere cell phone signal reaches, ADS-B signal also can reach. It's just a matter of infrastructure. And $$$$$$$$$. Should be online around 2020.
-- Campy
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
PostPosted: Fri Apr 11, 2014 6:24 am
Thanks for clarifying the FAA transponder issue, Brev..
Had done some "blog hopping" and should have instead gone to the FAA rules pages!
You must be a "flyboy".
PostPosted: Mon May 05, 2014 2:52 pm
You could say that. For the most part, if I can figure out how to start the engines, I can fly it. Or as the old joke goes, "I can fly the box that thing came in." Not a whole lot of point to committing all that crap about the FARs to memory otherwise. Not even for game shows. I don't think I've every heard a single question on Jeopardy that came from the FARs.
Pity, really. Very short-sighted of them. Woulda stopped that Ken Jennings character dead in his tracks.
Ken:
Alex, I'll take General Preflight Rules for two hundred.
Alex:
An airplane may not be intentionally be flown into instrument meteorological conditions unless its altimeter tested within this many feet of the airfield's published elevation.
Ken:
...... uh .......uh ...
Alex:
Five seconds, Ken.
Ken:
What is, a hundred?
Alex:
No, Ken, I'm sorry. The correct answer was, What is 70. Seventy.
I'd be rolling in the floor.
-- Campy
PostPosted: Tue May 06, 2014 8:56 am
Time marches on.
US Army Testing Pilotless Black Hawk Helicopter
-- Campy
PostPosted: Tue May 06, 2014 10:31 am
cool - now all those crazy good pilots in games like battlefield can put their skills to better use than killing me all the time. =)
that, or maybe now i can qualify as a combat pilot!
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Tue Aug 19, 2014 7:28 am
The US Navy is conducting its first carrier flight deck operations where autonomous UAVs are mingling with manned a/c.
The funny thing is, every landing by every pilot on a carrier gets scored. There's a bulletin board in a ready room where every pilot's landing scores (and their ordinal ranking) are on display. Getting the plane safely back onto the carrier is one of their most coveted skills, because the only alternative is throwing a 60 million dollar jet into the ocean. So I wonder if they put the UAVs' scores are on that same board. They cut sea trials short because the UAV's landings all were so consistent, so nearly perfect, there was no point burning the extra fuel. On the one hand, it would give the pilots a perfection to aspire to. On the other hand, it sure could deflate a lot of egos, and I'm not sure you want a fighter pilot feeling intimidated by a robot.
-- Campy
PostPosted: Wed Aug 27, 2014 6:07 pm
Drone delays medical helicopter landing at OH hospital
-- Campy
PostPosted: Fri Aug 29, 2014 7:27 am
The 'movement' would appear to be picking up momentum.
Google drones tested in Queensland
A fiendishly clever adaptation. This one uses the tail-sitter concept, first tinkered with in the 1940s by Fockewulf, then picked up a decade later by NASA when they'd got the VERTOL bug up their butt, but pretty much has been languishing in obscurity ever since.
Fockewulf's version:
Google's version:
-- Campy
PostPosted: Fri Aug 29, 2014 3:14 pm
That 'Fockewulf' version must have been a nightmare, with the huge bearing cage for the spinning wings.
And keeping the fuel lines to the jet engines from leaking!!
There is some advance with "micro" drones.. those only about the size of a humming bird.
They have a camera, and can fly about eight minutes. But they don't like nectar! :lol: :lol:
PostPosted: Thu Sep 11, 2014 9:04 am
Wot the do do... until we're teleporting margherita's then let the scooters fly.
I took a look at it.. Its not broken now!!.. but its not fixed either!!!
