AOpen AX4B-533Tube - The Vacuum Tube MoBo
Postby Hardware Junkie » Mon Jun 03, 2002 8:44 pm
Postby Wyrm73 » Mon Jun 03, 2002 9:16 pm
Cool, but don't vacumn tube produce a lot of heat? (No word play intended)
Wyrm73
Postby Hardware Junkie » Mon Jun 03, 2002 10:15 pm
Vaccum tubes are before my time. I have no idea how this will affect audio. :?: 8O :?:
Postby len444 » Tue Jun 04, 2002 8:35 am
personally, i wouldn't touch it w/ a 10ft pole- regardless of what they say- tubes are so antiquated (WTF)?!?!?
btw, where are those thumbs down emoticons?!?
len444
Postby useless comment » Tue Jun 04, 2002 9:41 am
It just goes to show that even after all these years there are still some things that analog will always do better than digital. IBM figured that out over 15 years ago when they started using analog display adapters because the digital just couldn't cut the mustard.
useless comment
Postby datektrader21 » Tue Jun 04, 2002 10:18 am
here ya go Image
i saw this one while getting the thumbs one
thats just wrong :!:
pm to have it removed.
datektrader21
Postby MoboCop » Tue Jun 04, 2002 12:14 pm
what is he doing? Brushing his teeth? ewwww
MoboCop
Drunken Master
Postby Hardware Junkie » Tue Jun 04, 2002 1:30 pm
Dense Mobocop...very dense...
Use your imagination....
Postby Wyrm73 » Tue Jun 04, 2002 3:43 pm
Most audio freaks will tell you that tube amplifiers are far superior to digital. I don't see those audio freaks accepting what has to be a slimmed-down version of an amp in their computer. Add this to the heat factor and this one has to fall in the nice try but still a bad idea catgory.
Wyrm73
Postby evasive » Tue Jun 04, 2002 3:48 pm
I will almost die in all the HF EMF fields generated by all the other switched-mode power circuits. Unless you put in a linear power supply with a transformer (anyone remember what a 400W transformer looks like? Right....)
Return to The Water Cooler
