Video Choppy after long time turned on
Postby Fridgester » Tue Dec 12, 2006 7:02 pm
I noticed this when using ATI Tool with the 3d view open. If the comp has only been on for a short time the cube rotates smoothly. If my comp has been left on over night downloading and i start ATI tool up in the morning the cube in 3d view is jumpy/stutters all thou the fps monitoring outputs the same fps as usual.
Restarting immediately fixes the problem. ATI Tool says it idles at 53C fan at 35%.
Fridgester
Return to Tech Support
