It is currently Fri Jan 18, 2019 6:30 pm
PostPosted: Fri Nov 11, 2005 8:57 pm
how unique is the cable? they have a whole slew of different 1394 cables at newegg. i was able to find some fancy stuff there before. 9-6 pin stuff and such.
http://www.newegg.com/Product/ProductLi ... der=priceD
does the unit power up? i've also seen problems on a couple enclosures i have that the power cable is the problem.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Fri Nov 11, 2005 9:48 pm
looks kind of like this one...
could the end have been damaged on yours?
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Fri Nov 11, 2005 10:51 pm
Standard mini USB Firewire cable.. You get two types, male or female...Both look very similar, you need to know which... Likewise the cable looks very similar to a mini USB cable...
PostPosted: Sat Nov 12, 2005 7:23 am
Firewire can use plastic or glass fibers for the transmission medium, to transfer data. Or it can use the Cat5E type of Network wiring. The plastic or glass fibers are not as resillient as solid wire, and may crack.. interrupting the data flow.
The only way to check for a bad cable is to test it with another known-working setup. Or substitute a known-good cable on your device.
Users browsing this forum: YandexBot [Bot] and 3 guests
