It is currently Sat Dec 15, 2018 7:38 pm
PostPosted: Fri Nov 11, 2005 6:52 pm
Got new computer but computer seems to loose connnection to the network. The only thing that helps is either to restart computer or disable ethernet card in device manager and then turn it back on.
I got my Marvell ethernet card turned on right now, but could not figure out how to turn on the other ethernet card. I had ther other on-board Nvidia card on awhile back and it did not give me any problems... but I do not know what settings I have to change in Bios to turn it on. Does anyone know?
PostPosted: Fri Nov 11, 2005 7:01 pm
you only need to run through the variouse bios pages untill you come to the setting, it will be on the same page for your on board sound,RTFM.
PostPosted: Fri Nov 11, 2005 7:07 pm
i found the page with ethernet card setting and I tried a few thing but i could nto get it to work. I just wanted to see if someone knew what settings have to be for the nvidia's lan card.
AMD x2 3800
DFI Lanparty SLI-DR mobo
2GB RAM
EVGA 7800GT CO video card
