What is involved in replacing a BIOS chip?
Postby jackdav » Thu Apr 28, 2005 8:56 pm
I am pretty sure I fried one while trying to flash via the internet.
Are they soldered in? Within a broad range, what might I expect to pay for one for a MSI KT8 Neo? Where might I want to start looking? MSI, I spose. Anywhere else?
TIA,
JD
________
easy vape reviews
jackdav
Postby headofmax » Thu Apr 28, 2005 9:02 pm
try the sticky up top about getting pins fixed
http://www.motherboards.org/forums/viewtopic.php?t=72206
DFI Lanparty Venus
Opteron 165 @ 2.8
Thermaltake Big Typhoon
2X1024 G.Skill
ATi 4770
GameXtreme 700W
LG 37" 1080P LCD
Hannspree HW191D widescreen
headofmax
Postby Sabrewings » Thu Apr 28, 2005 9:05 pm
Depends on how they built it. The chip on my board is replaceable. The chip on a bud's Intel board is soldered on. Just check it.
If its soldered, I'd bet it won't work. You'd need some machinery like the guy in the link above uses. He fixes for $50.
Sabrewings
Postby Pette Broad » Fri Apr 29, 2005 12:48 am
You're in luck, you have a socketed Bios on that board. I had one repaired here
http://www.flashbios.org/
It cost me less than $10, but its in The Netherlands. There are however plenty of other companies that will repair or replace Bios chips such as
http://www.badflash.com/
They charge $24.99 for repair and are based in the U.S
Pete
Pette Broad
Gem.
Postby jackdav » Sat Apr 30, 2005 1:15 am
You got MSI to replace a chip from an Asus board for free? You must have a great phone voice!
________
BMW M54
jackdav
Return to Tech Support
