It is currently Fri Apr 03, 2020 3:26 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sun Jul 18, 2004 7:53 am
Power Supply Tester:
http://www.newegg.com/app/ViewProductDe ... 905&depa=0
PostPosted: Tue Aug 03, 2004 3:56 pm
http://www.48bitlba.com/
hardrive install
 Post subject: DRIVE IMAGING SOFTWARE
PostPosted: Mon Aug 16, 2004 7:27 pm
Digital Dolly is a freeware drive imaging utility for home users. It works fine you will just have to read the manual carefully. You will have to make a FAT32 partition to save an image of a NTFS system partition. Don't forget to mount the partition or drive that you want to save to.
http://www.innotrix.com/digital_dolly/download.htm
* GIGABYTE GA-EX58-UD4P Motherboard
* Intel Core i7 920 Nehalem 2.66GHz
* MSI R4670-2D1G/D3 Radeon HD 4670 1GB
* Crucial Ballistix 3GB DDR3
* WD Caviar Blue WD800JD 80G
* Antec EA750
* Samsung LN52A650
PostPosted: Mon Sep 20, 2004 8:17 pm
Prime95 - http://www.majorgeeks.com/Prime95_d4363.html
"This program is a good stress test for the CPU, memory, L1 and L2 caches, CPU cooling, and case cooling. The torture test runs continuously, comparing your computer's results to results that are known to be correct. Any mismatch and you've got a problem! Note that the torture test sometimes reads from and writes to disk but cannot be considered a stress test for hard drives".
Prime 95 Torture test - an excellent little program for cpu thermal and/or stabilty testing in overclocked or normal system setups.
 Post subject: Toggling Screen Saver
PostPosted: Wed Sep 22, 2004 7:33 am
Ran across an article in PC World today where it gives a method whereby you can toggle your screen saver with a single click.
Useful for preventing the screensaver from interfering with burning, degragging or other activities without the difficulty of navigating to the dialog box to do it within display properties.
Not sure where it would be best to post this, so if somebody thinks it ought to be moved then by all means go right ahead.
http://www.pcworld.com/howto/article/0, ... 423,00.asp
Antec NeoHE 550
AMD 64 X2 4600+
ASUS A8N-SLI DELUXE
Corsair XMS (2X512)
Maxtor SATA (2x300GB) RAID 0
PostPosted: Thu Sep 23, 2004 6:49 am
New BHO scanner.
http://pcworld.com/downloads/file_descr ... 611,00.asp
Looks promising.
PostPosted: Sat Oct 09, 2004 4:37 pm
Crap Cleaner
Join the Motherboards.org Folding Team 33258
PostPosted: Sat Oct 16, 2004 7:10 am
Startup Library list:-
http://startup.iamnotageek.com/
Aussie
 Post subject: Re: System Fan GA7ZX
PostPosted: Wed Oct 27, 2004 9:43 pm
Hijack This Log analyzer:
http://www.hijackthis.de/index.php?langselect=english
RIAA vs The People
PostPosted: Thu Oct 28, 2004 5:58 am
Lots of good suggestions for "software" tools, but no "hardware" tools.
If I may add, the "good" computer toolbox should not be without a few different types of Hemostats, for picking up those dropped parts in tight places, or removing/installing the jumper caps on pinset headers. Also a decent-sized pair of end-nipper pliers, to cut protruding wire ends from circuit boards. Work well at squeezing the "arms" on plastic standoffs for removal. Crutchfield's catalog is one source.. there are many others, including medical supply houses, for the Hemostats. The pliers and other tools are available at most hardware stores. A pair of "chip poppers" similar to the ones made for removing the older '486' CPUs will be of assistance in removing any CPU from its socket, if you have no fingernails to get under the chip. Gently, of course!
