Toolbox utilities and essentials
GG
Post by GG »
Do we really need this thread? Shouldn't we just update the following one:
viewtopic.php?t=26326
Copper
Post by Copper »
WinUndelete
File Size: 873 KB
content_startWinUndelete is an easy-to-useutility to recover deleted files from hard drives, floppy disks, ZIP drives, USB external flash drives, digital camera cards and more.
Recovers deleted files even if the Recycle Bin has been emptied
Recovers files deleted accidentally from a network share.
Recovers files deleted from the DOS command prompt.
Recovers lost or deleted files by other programs, or virus.
Minimum Requirements: Windows 98/ME/NT/XP/2000
License: Shareware
http://www.jumbo.com/file/11802.htm
Copper
Post by Copper »
Contact:
Post by evasive »
GaryG wrote:Do we really need this thread? Shouldn't we just update the following one:
these are general tools and utilities. the thread in question is about security/adware&spyware removal/antivirus stuff. you can leave at least half of that out by using your brain before opening weblinks or emails btw ;)
RSheasley
Post by RSheasley »
Wookie8662 wrote:EasyCleaner is a small program which searches Windows' registry for entries that are pointing nowhere. EasyCleaner also lets you delete all kinds of unnecessary files like temps, backups etc. You can search for duplicate files and you can view some intresting info about your disk space usage! You are also able to manage startup programs, invalid shortcuts and add/remove software list.
http://personal.inet.fi/business/toniarts/ecleane.htm
EBCD is a bootable CD, intended for system recovery in the case of software or hardware faults. It is able to create backup copies of normally working system and restore system to saved state. It contains the best system software ever created, properly compiled and configured for the maximum efficient use.
You may download image builder utility which creates image of bootable CD-ROM (.ISO file), plus basic set of system tools. When the image is ready, write it to CD-R or CD-RW, and then everytime you'll need convenient and powerful system tools they'll be just at hand.
It is easy to customize the disk for your needs. You can include to CD any program you like, or remake the structure of CD completely. All you need is to change a few lines in configuration XML files.
http://users.i.com.ua/~ebcd/website/
Is it just me or has the Boot CD been taken down? I see on the list software like Symantec's Norton Utilities so I suspect the links are shut down...
Copper
Post by Copper »
RSheasley
Post by RSheasley »
Yes, the site is up but when you actually try and download the packages (either pro link or the Lite edition) they redirect you to either Simtel or another site and the download seems to be removed. So if it works for you did you just try the page or get the download to complete?
iwillast1962
How To Repair Windows XP
Post by iwillast1962 »
iwillast1962
How to Retrieve Windows CD Key all vers. for home or office
The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry. It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping. It works on Windows 95, 98, ME, NT4, 2000, XP, Server 2003, Office 97, and Office XP. This version is a quick update to make it work with Windows Server 2003. :D :D :D
Davvo
Post by Davvo »
ESP matting to prevent those nasty shocks.
Davvo
Post Reply
